Body Vents in the Trunk
Old Oct 31, 2009 | 09:34 AM
Hessian's Avatar
What are these used for? There is a vent on each side in the lower back area of the trunk.
I was thinking about sealing them up for an IB install.
Old Oct 31, 2009 | 09:56 AM
houtex's Avatar
The car needs to breathe. Doors opening/closing, air pressure changes during the day/night, and moisture removal are three items that would be affected if the vents weren't there. So don't.
Old Oct 31, 2009 | 02:22 PM
Hessian's Avatar
An IB install will seal off the trunk from the cabin, so if they only serve to vent, they probably could be sealed up as they would only vent the trunk at that point (which is usually what you don't want in IB).
On the other hand, they may help in my case. I'm going to leave them alone for now and try sealed, unsealed, and test them as variovents also.
Old Oct 31, 2009 | 03:19 PM
houtex's Avatar
Well the amount of stuff going on... I doubt they'll do much. If your box is already sealed up to the passenger compartment, it won't affect the subs either way.
Hey, it's your car. Do it.
Old Oct 31, 2009 | 05:31 PM
05GT-O.C.D.'s Avatar
I lust for a M24
IB?
Houtex is right, when you close the doors they allow the excess air to escape, allowing your door to close easier and preventing additional wear on your seals. Stand by the vent and have someone close your car door and you'll see them in action.
Old Oct 31, 2009 | 07:27 PM
Hessian's Avatar
Originally Posted by 05GT-O.C.D.
IB?
IB = Infinite Baffle
With an IB setup I can lose the weight and get back space from having a full sealed box.
I'll have 2 ~12 inch Dynaudio 190s installed in the rear deck.
Old Oct 31, 2009 | 07:46 PM
I lust for a M24
I guess I'm old school, we always called that Free Air.
Old Oct 31, 2009 | 10:33 PM
houtex's Avatar
Actually, after reading about it... you may want to leave the vents alone because, in reality, they're adding to the 'volume' of the enclosure... i.e, the world's entire atmosphere excluding the passenger compartment of your car.
Whether you leave them open or not, however, it's likely to not produce any results. You're defeating the use of them by blocking off the passenger compartment. Their only use, therefore, is the trunk... and you might want that venting so you don't blow out the cones when you close the trunk lid.
Leave them things alone, you will gain nothing by blocking them.
/My final answer, Regis.
//Again, your stuff, we don't count.
///But it's fun to kibitz.
kponypower
Jun 17, 2020 07:17 AM
GLOCKer
Sep 28, 2015 05:20 PM
TMDM
Sep 24, 2015 07:00 PM
