Billet Pedal Covers
I think steedas are the cheapest right now at $45 for the pedals (3) and $35 for the dead pedal. Roush has some to at $92 for the manual and $80 for automatics without a dead pedal I believe. I don't know of any others.
As far as ease of replacement. There was a post not to long ago in the interior mods section. You might search for it, but if I remember correctly you have to remove the covers from your pedals before adding the new ones. One of the pedals is easy to remove, the others aren't. Then you just drill holes for the new ones.
Steeda's
http://www.steeda.com/
Roush's
http://www.jbcmotorsports.net/jbcmotorsports_085.htm
Steeda's
Roush's
Saw some new ones. UPR has some $69.99 for manual tranny or $59.99 for autos. Not the cheapest, but it is another option.
www.uprproducts.com
www.uprproducts.com
Originally posted by rap1977@March 12, 2005, 7:20 PM
Guess I wont be getting the UPR ones. I dont like the idea of drilling holes in the pedals, anyone wlse feel that way or is it just me?
Just got the Steeda pedal covers, and tried to install them tonight. what is with the fit of these things?? . The Steeda hole pattern leaves no meat on the pedal in the present Steeda fastener locations. Has anybody done this install and used all 4 holes for fastening to the pedal. I think Steeda should have provided a tool or template for drilling these holes. :bang:
Can anyone give any helpful advice to installing this mod???
I installed the UPR covers. I broke the bit on the last hole. Fortunately it was enough to get the cover on. The brake pedal was the hardest because my drill was almost to big to fit between the pedal and the dash. The Acc and Clutch pedals were pretty easy.
I was kinda disapointed that they cost $70. Doesn't seem close to $70 worth of metal and labor. But they look nice.
Originally posted by MTAS@August 1, 2005, 4:45 AM
Use a titanium drill bit and a variable speed drill. Start off very slow to let the bit start a hole and not wander all over the place. Once it's got a good start, increase the speed. This worked for me.
Originally posted by davids2toys@August 1, 2005, 12:37 PM
were you able to pick up all 4 holes?
Originally posted by MTAS@August 1, 2005, 6:39 PM
Yep - just make sure you have the pedal in a position so as many of the 4 holes can get as much meat as possible.
Originally posted by davids2toys@August 2, 2005, 2:20 AM
OK, also, the cover contours different than the pedals...will it pull in?
Originally posted by MTAS@August 2, 2005, 4:40 AM
If you mean the screws, yeah they'll pull in, but the covers won't get flat - they'll have the curve to them![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
I think the gas pedal should have been self tapping screws, due to the underneath construction of the original plastic pedal. must be real careful where you drill or you wont get the nut on!
And lastly, be very careful at first when you drive the car, the brake pedal cover is much bigger than stock and is much closer to the gas pedal than before, if you are not careful to keep your foot in the middle of the brake, you will catch the gas pedal 3/4 of the way down...not a good feeling i can asure you!
Don't mean to be negative, i actually like them a lot, just giving a little review.
