Auto radio cut off when door opens?
Old Apr 25, 2007 | 06:54 PM
sscobra's Avatar
I am looking for any information about this feature. I am about to help a friend intall an aftermarket head unit and I wanted some information about this feature. Such as: If you install the head unit with the correct metra harness does this feature automatically work? If not, what is need to either make it work or bypass this feature? Or, are there any issues I might incounter with the install relating to this feature? Any help is greatly appreciated. Thanks in advance.
Old Apr 25, 2007 | 06:57 PM
Dirty Sanchez's Avatar
head unit stays on till a door is opened
Old Apr 25, 2007 | 07:05 PM
mikes rx's Avatar
The feature is built into the wiring of the car, not the radio itself. For example, I have my homelink mirror, satellite radio, and shift light all on the same circuit as the radio, and they all remain on until I open the door.
Old Apr 26, 2007 | 03:32 AM
G.T's Avatar
G.T
if the headunit draws power from a switched accessory line (which i assume it is), it will be powered up as you turn the ignition on, and remains on till you turn the ignition off and open the door (turning off the ignition and removing the key but remaining in the car will keep the accessory power on for about 10 minutes)
Old Apr 26, 2007 | 07:03 PM
sscobra's Avatar
I found out that they are keeping the factory head unit and we need to find the best place for the amp remote wire. I searched and didn't really see a lot of good options. I just saw someone use one of the unused fuse locations in the fuse panel. What other options are there? Thanks again for any help.
Old Apr 27, 2007 | 07:12 AM
G.T's Avatar
G.T
well unless you wanna tap in an already laid out wire.. using an unused fuse in the passenger side fusebox is the cleanest approach!
kponypower
Jun 17, 2020 07:17 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
Sep 30, 2015 07:02 PM
