Anyone know where I can tap into a 12v source?
Old Apr 29, 2005 | 01:26 PM
Chaotic Bliss's Avatar
I want to mount my G-Tech permanently and I don't want to use the cigarette lighter for power. So I bought a spare power cable and I want to cut it and tap it into a 12v power source. Anyone know where I can find one somewhere in the driver side foot well? I would prefer one that turns on and off with the ignition.
Any help is appreciate.
Rob
Old Apr 29, 2005 | 01:32 PM
MTAS's Avatar
Don't know of one for the driver's side foot well, but in the fuse box in the passenger side foot well, there's a fuse for "OD shut off" or something like that. Check the owner's manual for exact location within the fuse panel. Other's here have used that for a compass/mirror, and I used it to power the light on my Autometer gauges.
Old Apr 29, 2005 | 01:53 PM
Ya I just wanted to be lazy and use something close to the drivers side but that one sounds like it might work out. How exactly do I tap into something on the fuse box? I am used to tapping into a wire.
Old Apr 29, 2005 | 01:55 PM
Tiberius1701's Avatar
The passenger side footwell fuse panel is the best place to go. I ran my XM receiver power there, purchased an Add-a-fuse (I think that is what it is called) kit from AutoZone. It worked really well.
Old Apr 29, 2005 | 02:00 PM
dustindu4's Avatar
9 is not my lucky number.
you can buy a wire tap that piggy backs over a fuse in a fuse box. It essentially gives a double fuse on 1 fuse box connection and it has a wire sticking out of it (positive end). Stick in whatever fuse you want to use, plus the one that was already in it, and connect it to whatever you're installing. Tie the negative end to a screw on the body and you've got your circuit. You can buy these in the fuse section of Pepboys. I just installed a start button from a Honda S2000 today and will be posting pics up later. You can use the same concept for your application.
Old May 2, 2005 | 09:19 PM
dustindu4's Avatar
yes look here
http://forums.bradbarnett.net/index.php?sh...ndpost&p=351583
Old May 3, 2005 | 07:39 PM
ChrisM's Avatar
At Pep Boys, it's called "Add-a-Circuit". I just used one for the power mirror I installed.
Be sure you get the one for mini fuses! I planned ahead and bought the large size only to find out in the middle of my mirror project that the mini size was needed. Had to stop and go back to visit Manny, Moe and jack to get the right size!
RCooke08GT
Feb 19, 2017 03:03 AM
