Aftermarket stereo/voltage regulator
Old Sep 2, 2006 | 08:49 AM
Jet's Avatar
Jet
Exclamation Aftermarket stereo/voltage regulator
Just a heads up if anyone's planning on installing a new deck. You may need a voltage regulator (http://www.radioshack.com/product/in...tId=2062599&cp) on a lot of aftermarket stereo's for our beloved new Stang. I wasn't aware that I needed it at first, and my new Kenwood would make a poping sound from my speakers when I turned on the stereo. Crutchfield gave me the answer I needed with the part listed above. It sounds strange, but it worked.
Old Sep 2, 2006 | 06:59 PM
pouterson's Avatar
Yep, I had the same problem. I put that regulator in and no more pop, almost. Every once in a while, I get a lower pop after shutting off the car and opening the door while the stereo is still playing.
Old Sep 3, 2006 | 02:05 AM
Jet's Avatar
Jet
Hmmm, that's really strange. The excess voltage should travel to Ground since it's the path of least resistance. Where did you Ground the regulator to/did you ground it? I just used a pigtail with the ground wire coming off of the receiver and it's quiet (knock knock).
Old Sep 3, 2006 | 07:20 PM
Infinity's Avatar
Just a reminder also, you should only use the regulator with factory amplifiers. Most aftermarket amps will NOT work with the regulator. They require 12v on the remote lead.
Back to your regularly scheduled thread.
May 3, 2026 05:42 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Sep 24, 2015 08:15 PM
AlphaM1
Sep 24, 2015 03:30 PM
