Aftermarket head unit with Shaker amp?
Old Oct 30, 2006 | 01:39 PM
clintoris's Avatar
I just installed a Kenwood head unit, and I am just a cut above retarded, so I don't know what I did wrong here...
Only the lower door speakers are ampped.... the rear speakers and the upper door speakers are so quiet, you almost can't tell they're even working. I ordered a wire harness from Crutchfield http://www.crutchfield.com/S-exs4Zip...sp?i=120705521 and spliced everything together... the problems I ran into is that there was a huge pop when the amp was powered up... so I bought a voltage regulator with a 5v output becuase the Kenwood has a 12v output.... so I had to do some riggin' there, and then the little harness that has the RCA pigtails... I just plugged those into the rear channel on the back of the Kenwood... assuming it would amp the rear speakers. Well.. no... it didn't. It's the doors. So I moved it to the front channel... and again, just the lower door speakers are ampped. Now... you guys will have to go easy on my, 'cause I know next to nothing about this stuff. Does anyone have any suggestions? Has anyone tried to use the factory amp with an aftermarket head unit?
Old Oct 30, 2006 | 08:33 PM
cgallo52's Avatar
First, make sure the internal amp in the DPX701 is turned on (via menu) this should power all 4 speakers... If Shaker 500, the crutchfield harness will need a Y adapter. The 500 has mono sub input (Y adapter L+R sub into shaker sub) , both front subs input is the mid sub or something like that on the diagram.
May 3, 2026 05:42 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
Sep 30, 2015 07:02 PM
Sep 24, 2015 08:15 PM
