500 shaker external amp? not conected to the head unit?
Old Mar 11, 2011 | 04:09 PM
bmw_686's Avatar
so i have a 05 gt with the 500 shaker and it sounds soo good but i have a alpine head unit that i want to install. my question is dose the 500 shaker have a amp that isent part of the shaker 500 head unit so when i hook up my alpine deck it sound sjust as good and loud.
Old Mar 16, 2011 | 05:57 PM
Cavero's Avatar
It has separate amps for the subs only. the regular speakers are driven from the head unit itself. The sub amps also have a +5V turn-on signal, but most head units output 12V. If you're in that boat, you can buy a $1.50 voltage regulator from radio shack and splice it into the wiring harness you make for your head unit.
Old Mar 17, 2011 | 07:01 AM
05YellowGT's Avatar
+1 , there's a how too in TacoBills sticky ...
Old Mar 17, 2011 | 08:53 AM
godspunk32's Avatar
If you're going to install an aftermarket deck, pick up the PAC C2R-FRD1 wiring kit, as it includes everything you're going to need. Make sure you connect the blue/white wire from the deck to the blue/white wire from the FRD1 harness, and plug the green/purple RCAs into the sub-out from the deck.
JR
Old Mar 19, 2011 | 03:58 PM
ETNOATS's Avatar
The PAC harness is great for plug and play but is not nessasary. The standard metra harness works fine and saves money. The new HU will make a huge differance in the sound. I can FELL my door subs hitting now.
duppycat
Feb 16, 2019 08:36 AM
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
earl610
Sep 7, 2015 11:57 AM
