2009 gt sound system upgrade
I'm looking to upgrade my sound system from the shaker 500. My budget is around $1200. For head unit I'm looking at alpine cda-117 or kenwood excelon x996. I would like to replace the 2 door speakers and 2 rear speakers for now as well.
Will the stock door subwoofers work with an aftermarket HU? Will I be able to hook up the existing siriusxm to the aftermarket HU that is siriusxm ready?
Any suggestions for a good HU and speakers? (prefer single din) Also might get the shelby kicker subwoofer, would those work off the HU without an amp?
Do you think getting an amp is a good idea?
You can look at some other threads but all your speakers will work with an aftermarket HU. It will tie in to your stock amps from the 500 system.
The shelbys are ok, if your willing to fiddle theres better. They drop right in with a spacer so thats a plus if you want easy installation. They will work fine off the stock amps, but of course, will sound better on an aftermarket amp.
For the speakers it depends on what you want to do. If you're willing to do a little modification a good componet set up front will do wonders for sound. The back you can just replace with a decent 5x8 set.
Crutchfield says I need to buy a new sirius tuner with the head unit?(it is xm compatible). I'm looking for a HU with good sound quality, also xm, hd radio, usb.
Rather not do any modding if that is what a component system requires, just speakers.
jl-audio c2-570x looks nice anyone have these?
Ordered the Alpine CDE-HD138BT since it had the features I was looking for: good sound, usb input, siriusxm ready, hd radio, plus blutooth and pandora. Also ordered 4 JL Audio C2-570x speakers, siriusxm SXV200v1 tuner since the factory sirius tuner doesn't work with aftermarket HU apparently, door panel clip removal tool, 4 speaker harnesses, 2 foam baffles, and a mastersheet from crutchfield.
No amp or subwoofers for now. Total cost about $510
