2008 Factory Nav - Voice clarity issue
When my Factory Nav says a street name it is ussually garbled or it sounds like there is multiple voices stating the street name. An example would be, "make a left onto.. Livingston Court". The only part that would be hard to understand would be "Livingston Court". I know that being able to say a street name as opposed to just "turn Right" was supposed to be a big advance, but the voice clarity is horrible. I am hoping that maybe it is a software problem. Is Your Nav system clear?
I have not yet gone to the dealer for help on this one. If someone else already dealt with it and had it fixed, it would be helpful to know the fix before going to the dealer.
I have only had the car for 2 months so it has had this problem since I picked it up.
=Vic=
Yes, I figured that you can adjust the Navigation Volume while it is talking with just the volume **** and it holds that volume for good after that. I am going to the dealer to ask about its clarity. I find it hard to believe that this is what the finished product is supposed to sound like. I will let you know what the dealer says about it.
I get a computer fault every time I start the Nav or try to set a Destination. I can click OK to clear it but it is a pain. The local Ford radio guy tells me it is asking the vehicle if it is an F-150 and it says it is a Mustang back. OOOPS. Does anyone know how I can bring the 2 together???
A prior owner swapped out the Shaker 500 head for a NAVTEQ from an F-150. Works fine but I have the same voice issues, particularly with words of more than 2 syllables.
=Vic=
Went to the dealer and the Tech went for a ride with me. The Tech agree's that the street names sound "wacky". He has to call a Rep and get/give some info and call me back.
I am glad that someone agree's with me about the sound. I was about to just deal with it as is.
I will let you know more when I know more.
My Phone just rang and it was the Dealer. They said that some of the early 2008's (this car was Delivered in April) had a bad module in the head somewhere and they will replace the Head as the fix. Sounds too easy to me. We will see.
Thanks. Now to find someone who can do it. The local Ford guy doesn't (or won't) know how...you know...modify their own stuff! Could NavTeq help or is there an aftermarket way to reprogram it.
BTW, the Shaker sub is working fine.
=Vic=
I found the place the area dealers use, about 70 miles away, but they wanted about $150 to reprogram my Nav Radio, so I used a service advertised on eBay...Chicagoparts...and they did it for just under $100. It seems as cars get more and more computerized, the radios depend on being able to decode digital signals in order to properly interface with the car. Good luck.
=Vic=
=Vic=
Well the dealer changed the head a couple of weeks ago and it did not change the voice clarity issue. Tomorrow the same dealer is going to put the newest NAV Disk in and see if it helps. If it helps they will give me the disk under warranty, if not, I am out of luck.
Beargap,
I am starting to believe your voice synthesizer text-to-voice algorythm stuff. This might be as good as it gets.
Let you know
Beargap,
Let you know
The Latest:
Well the dealer has changed the Head unit and updated the disk to the most recent 7P. Sounds the same
They even had 2009 Mustang with the same Nav System & disk. I took it for a ride and it sounded identical. I am truley amazed that this was a $2000 option and this is what the final Product is supposed to sound like, needless to say I am disappointed.
2/10/17 07:12 PM
Fred_Garvin
9/17/15 04:10 PM
