Yet ANOTHER wheel question
Old Mar 12, 2008 | 12:11 AM
crewcutkid's Avatar
So I read a few pages into the threads here regarding wheels, and I'm a little backwards on the terminology- could anyone sort of spell out what everything means, and any synonyms (for instance is backspacing the same as rear spacing, etc...) I only ask as I'm trying to find out if a certain wheel will fit an '07 GT, and I'm not up on wheel/tire lingo.
Oh, I should probably post the wheel I'm looking at- it's the Cragar Soft 8 397 series- it's a steel wheel, with all sorts of 17" dimensions (I'm not looking to get a bigger wheel, just a different one). There's a chart of the different sizes of this wheel here, with lug patterns, "rear spacing" (backspacing?) and other dimensions. Link HERE
Thanks for any and all assistance!
-Jim
Old Mar 12, 2008 | 05:10 AM
swissdan's Avatar
Here links about rims tech: http://www.1010tires.com/tech.asp or https://www.rsracing.com/tech-wheel.html#backspace or the small diagram at bottom to explain
You will also find an wheel offset calculator to choose new rims.
Just some datas to know about s-197 Stang:
  • stock V6 rims: 16" X 7" offset 39mm
  • stock GT rims: 17" X 8" offset 45mm
  • option rims: 18" X 8.5 offset 50mm
all these rims with a bolt circle of 5 x 4.5"
I hope it will help you...
Old Mar 12, 2008 | 11:55 AM
crewcutkid's Avatar
Thank you, Swissdan. I'll take a look!
-Jim
Good Times
Aug 29, 2015 10:18 AM
salazamk
Aug 22, 2015 02:19 PM
junkman9096
Aug 3, 2015 10:58 AM
