wheel vs tire
Old Mar 5, 2006 | 12:20 PM
windevil's Avatar
hello all new poster long time reader , I just bought some gt 500 chrome knockoffs 18x9.5 all four
I will put bf goodrich dral radials on all 4 front is 255 45 18's and back will be 195 35 18's do you see any problem getting 295's on a 9.5 rim b f goodrich said 10 or higher for proper fit ... has anyone put a 295 35 on a 9.5 inch rim ... thanks for all replys Will
Old Mar 5, 2006 | 12:41 PM
TURBO 05's Avatar
if they recommend 10+ dont use your rims with those tires there is an increased chance that under hard cornering the tire can come off the bead. I am sure people on this forum will tell you that they run it that way and there is no problem but I highly dought they have the same knowlage as the engineers that designed the tires and decided what is safe and what is not safe
Old Mar 5, 2006 | 05:01 PM
windevil's Avatar
thanks I thought so , but the rims are 9.5 no bigger ones yet , I guess 285 35 18 would work ?
Old Mar 6, 2006 | 12:07 AM
Enfynet's Avatar
You'd be best off using 285/40s... You'd have about the same as stock diameter and you won't notice the 10mm as much as you'd think. I usually can't tell until I get to 20mm differences and larger.
Old Mar 6, 2006 | 03:33 AM
vc4life's Avatar
aww just do it and dont drive like an idiot and you will be fine [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Mar 6, 2006 | 04:29 AM
Joediveguy's Avatar
<div class='quotetop'>QUOTE(vc4life @ March 6, 2006, 5:36 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Mike, saw you were from Houson. You might be able to hel this guy, check it out.
http://forums.bradbarnett.net/index....opic=46208&hl=
I like the flaming bag of poo or pizza suggestion.
Joe
robjh22
4.6L GT Modifications
Aug 13, 2015 02:56 PM
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
junkman9096
Aug 3, 2015 10:58 AM
