Wheel Fitment Questions
I have been looking around at various wheels that will clear a 6 piston BBK, and I have always been very fond of the Advan AVS Model 5 Wheels and I was going to put them in Black. However a set of 4 cost around $2500, and I'd prefer to spend that money elsewhere, I found alternatives for under $800 for all 4 wheels. I want to know if the following specifications will fit a 2006 GT.
PCD: 5x114.3
ET: 42
Weight: 21.5lbs.
Here are some pictures of the $800 versions, the wheels on the NSX are the Advan JDM wheels.
![](http://www.edgeracing.com/images/gallery/gallery_20050128103450.jpg)
![](http://www.edgeracing.com/images/gallery/gallery_20050128103504.jpg)
![](http://www.edgeracing.com/images/gallery/gallery_20040920172220.jpg)
These are some examples of the wheels and the BBK clearance, thanks for your help!
PCD: 5x114.3
ET: 42
Weight: 21.5lbs.
I like them a lot and don't know if yours will fit, heres an example on my car of the 17 wheels and M+S runflats. I painted the centers silver because I didn't like the chrome center.
The wheels will fit the car, I won't promis brake clearance. I don't think you'kk be very happy with them. They are too narrow and it will look like your car is tip-toeing. If you MUST use only an 8" width, go for 30-35mm offset. That will push them towards the outside a bit, and it's much better than using a spacer to accomplish the same thing.
I did a little research, I am probably going to just save up and get the Advan Model 5's...
I can get them in 18x9 35/40/45 offset and 18x10 45 offset, which of these would be the best set-up, I want some meat on my tires
7/20/15 06:26 AM
