What size rims need I buy?
Old Jul 22, 2005 | 05:33 PM
billyclo's Avatar
I tried searching, to no avail. So, if I am looking to get rid of my wheels that come with the 06 GT, but want to use the tires that come with it....what size rims need I buy? 17 x 8?
Also, if the car comes with 17s, and I swap to 18s, do I understand correctly that that swap could result in the speedometer being slightly off?
Old Jul 22, 2005 | 05:51 PM
Kahdir's Avatar
To reuse the same tire would require the exact same size wheel; unless running on the sidewall doesn't botter you..
I think you can get away with a 1/2 width size difference... :scratch:
As far as the speedometer is concerned; try to equal the same height of your OE tires...
Even though they screwed-up my order, Discount Tire Direct has all the calculators you'll need.
Old Jul 22, 2005 | 05:57 PM
billyclo's Avatar
ok....so what size wheel comes with the car??!!
Old Jul 22, 2005 | 06:02 PM
Kahdir's Avatar
17x8 w/ 235/55-17
JonathonK
Feb 22, 2016 11:02 AM
Detroit Steel
GT350
Sep 3, 2015 07:50 AM
