Tires to match 20's
Old Mar 22, 2007 | 10:41 AM
WuTimeUT's Avatar
Tires to match 20's
Ok guys since I'm completly retarded when it comes to tire sizes, please help me out.
I'm going to order 20x8.5 on the front and 20x10.5 on the rear but I have no idea what tire to go with. I found a almost brand new set of 305/50R20s But I'm thinking that is just going to be to big. Will those fit? Up front I was looking at a used set of 255/35R20... I need some help here
Old Mar 22, 2007 | 01:00 PM
chris_fowler99's Avatar
305/50R20? You're gonna be about 7 inches too tall...
305/25R20 is going to be about as close as you could get.
Even 255/35R20 is going to be tall. 255/30R20 will come closer to stock.
Old Mar 22, 2007 | 01:38 PM
rocket88's Avatar
Use this nifty calculator and try to get the new tire size as close to the same height as stock
http://www.miata.net/garage/tirecalc.html
255/35/20 is a nearly exact match for the front, actually .2 inches shorter
Old Mar 22, 2007 | 01:55 PM
I typoed something into the calculator I was using.
27.2" is the correct height. I was at 26 for some reason.
yeah, 255/35R20 looks good.
305/50R20 is still way off...
Old Mar 22, 2007 | 04:29 PM
WuTimeUT's Avatar
I man the calculator is freakin sweet..... so what would be the way points. I mean whats the farthest from stock you could go without having problems?
Thanks for stayin with me.... I understand the 205 and the 20 but the middle number, the % i guess? I just dont get it...
Also what is the widest tire you could go withought having problems on a 10" and 10.5"?
Old Mar 23, 2007 | 07:43 AM
I believe the middle number is the size of the sidewall, as a percentage of the width.
Which, if I am correct, is so extremely odd...but standard.
Old Mar 23, 2007 | 03:08 PM
SlamMan02's Avatar
The middle number is the size of the sidewall being shown as a % of the first number...
For Example: 100/50/20zr - That means the width of the tire is 100mm - The side wall is 50% of the 100mm or 50mm - the 20 being the diameter of the tire (IE: Rim Size 17,18,20etc) - and the Zr refers to the speed rating of the tire where Zr is safe at 186+ mph
Old Mar 23, 2007 | 04:07 PM
WuTimeUT's Avatar
Yes I get the middle number is a % I just dont see the reason behind it. It just makes it a little confusing, but anyway I think I've got it down now
Old Mar 23, 2007 | 04:26 PM
WuTimeUT's Avatar
? so whats the biggest size someones running on a 10in? 285? 295? 305?
Old Mar 23, 2007 | 11:57 PM
MELLOWYELLOW06's Avatar
Here is exactly what you need. With 10.5 rears these are the best tire because you will have a mean wide patch in the rear.. Toyo proxes 4 (they are also m+s rated)
255-35-20 front
295-30-20 rear
Old Mar 24, 2007 | 05:45 AM
jcthorne's Avatar
Actually the Nitto 285 30 R20 has a wider contact patch than the 295 Toyos and MUCH better traction. You have to look at tread width in addition to size as it varies from brand to brand as does actual height.
Old Mar 24, 2007 | 12:33 PM
WuTimeUT's Avatar
Thats what I'm thinking but the problem is the wheels I'm looking at only go up to a 10" width.... I think I saw 295s on a 10" and it lookd pretty good
Old Mar 24, 2007 | 04:09 PM
My rears are 10" with 295's. Here is a better pic. I think the Toyos look great. As to the previous post regarding the Nittos, I don't own Nitto or Toyo Corp. so whichever tire you get the money will not be going in my pocket. Just merely stating they look great on 10" wheels, in my opinion and just about everybody else that has seen them. I got 555's on my SUV, they are great too.
Old Mar 25, 2007 | 05:25 PM
WuTimeUT's Avatar
hey joe that looks sweet man, so those are 295/?? on the back?
Old Mar 26, 2007 | 10:52 AM
295-30-20 toyo proxes 4 on 10"foose nitrous
Mar 30, 2021 09:29 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
cozyp828
Apr 18, 2016 09:46 PM
samjluck
Oct 26, 2015 05:17 PM
