tire pressure on 20's?
i just got my 20 inch bullitts and the first time my tire pressure light came on saying fault cause of no tps in the new wheels..... at first i forgot about those and checked my air pressure and seen the fronts are in between 26-28psi hot and rears are 32 psi hot...... so my question is this what should it be at.....the tires are nitto nt555 extreme 255/35/20 and the only thing on the tire saying psi was 50 lbs max im not about to put that much...... what should it be at cold and is there any way to disable the tps warning
The only way to disable the TPS is to get some sensors installed. You can usually find a set on ebay for around $100. There's a tool for the F150 that allows you to reprogram the sensors for your car. Costs about $15 and takes about 10minutes to complete. I run around 35-40 psi in my 20's.
in modern radial tires the recommended air pressure required is based on load/weight. whether you are running 17's or 20's, the same manufacturer recommended pressure is fine +/- a few psi. i run mine around 34-35.
the value on the tire (ie 50psi) is the max pressure for any load the tire can hold.
Give me more details on the symptoms you had at lower PSI.
Thanks,
well it had a bad wobble before the wheels cause my rotors were warped and glazed....... thats what ford said when i brought it in...... they replaced everything and the wobble was not as bad but still there...... put more air and its so minimal thats its basically not there...... bump them up if you dont notice a difference then go back to lower pressure
Good deal, just threw that out there since there is no reason to run your tires over 40 PSI. That is just going to cause wear issues.
Higher PSI in your tires does 3 good things for you. 1. Harder side wall = less chance of damaging your wheels on that unforeseen pot hole when you have a 35 or shorter side wall. 2. Reduces friction which = better MPG. and 3. Reduced friction also = better tire wear. Hence the reason why I run mine at 40 PSI all the way around.
"Disadvantages of Overinflation
An overinflated tire is stiff and unyielding and the size of its footprint in contact with the road is reduced. If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear. Higher inflated tires cannot isolate road irregularities as well causing the vehicle to ride harsher and transmit more noise into its interior. However, higher inflation pressures reduce rolling resistance slightly and typically provide a slight improvement in steering response and cornering stability. This is why participants who use street tires in autocrosses, track events and road races run higher than normal inflation pressures."
40-45 is going to be required on the rubber band of a tire to have the OE load capacity as the original tire. Smaller sidewall cannot support the weight at the stock 30-35 psi. Hey its your wheels, and tires that are going to suffer, not mine.
If so, I have no problem admiting I am worng because I want what is best for my car.
for 245-35-20 what would be the correct pressure?
Rando
8/25/21 11:12 AM
