Third Brake Lamp LED replacement
Has anyone replaced their 3rd brake light with a LED replacement? The owner's manual says to use a 921, which IIRC is the same physical form as a 194.
What size/model LED replacement did you use? I don't imagine the 921 providing any substantial amount of light, so I don't feel it is worth paying $130+ for the LED array replacement that they're selling online, but I am open to suggestions. I want to replace as much of the exterior lighting with LEDs as possible without resorting to load resistors to trick the SJB/BEC.
Interesting. How bright was the stock lamp? The 921 bulb can't be that bright and I figure I could use a $1 LED replacement in its place.
The $60 LED replacement looks good but they were well over $100 at Summit. How easy was the installation?
i have basically the same one as mtas. i think that is a MUCH better way to go than a single cluster LED bulb. from past experience, those bulbs are pretty dim. i can't remember how much it was, but it wasn't over $50 shipped to hawaii. got mine on ebay.
the one problem i had was that when the brake was not being pressed, there was a constant faint glow of the LEDs. what i ended up doing was putting a circuit in-line resistor and that did the trick (oh, just re-read your post and you don't want to do this). very easy to wire-up.
The problem is that the clear/red, clear, and smoke LED arrays don't match with Vista Blue. It'd look kind of "rice" with that color combination. Both your gray Mustangs look great with smoke or even clear, but I can't find an LED array with a red/OEM-style lens which is why I was considering a single LED replacement. I can't imagine the stock lamp being extremely bright in the first place.
How do you access the third brake lamp? I couldn't find a way to remove that black plastic housing in the trunk lid.
iirc, you just pull that black plastic cover. i don't quite remember, but i think you have to feed that emergency trunk open latch through an opening... there really wasn't much to it.
i guess if there isn't anything else blackish on the rear of your car, then yeah it may look a bit off. my car is alloy, so the 3rd light basically blends in with the rest of my trunk. not sure if you ever seen it before, but here is a pic of the stock 3rd brake light. would be really easy to just swap in an led cluster bulb.
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0004-3.jpg)
oh, or buy the clear LED tail light and then just buy some red tail light tint paint.
http://cgi.ebay.com/ebaymotors/2-Red...3QQrefidZstore
eh, yeah, maybe just try that cluster led bulb first... lol. but yeah, seems like the 921 and 194 are interchangable.
Soundwave: Cool pic! Do you remember if there was a reflector on that black piece that clips into the clear plastic? That looks like a funky diffuser setup.
hold on.... i will go downstairs and take mine off and snap a pic. should have pics up in a bit.
disconnect the emergency pull handle
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0014.jpg)
reach behind both sides and stick fingers into little space (sorry blurry. took pic with my left hand)
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0017.jpg)
firmly pull down with both hands
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0015-1.jpg)
cover only held on with 2 clips.
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0018-1.jpg)
from there, easy access to the 3rd brake light (i guess that resistor DOES get hot)
![](http://i116.photobucket.com/albums/o8/sound_wavez/DSC_0019-1.jpg)
Excellent pics!!! I appreciate you taking the time to take off the cover.
Have you considered switching the trunk light to a LED? I swapped my hot, power hungry, and yellow trunk light for a LED festoon capsule. I soldered on a glob on the festoon to prevent it from spinning, but it looks kind of cool.
I ordered a few 921/912 replacement LEDs to use as 3rd brake lights. Hopefully the SJB/BEC in the S197 doesn't throw a hissy fit, but I can also use them in my Crown Vic. I looked at the stock light and it's not that bright in the first place, but I want to get rid of as many incandescent bulbs as possible without resorting to load-down resistors.
Oh, and I didn't have to take any of that stuff off! That's a lot of work that I haven't gone through with either car I've owend.
Plug and play on mine, you have an entire line of LEDs and not just one bulb. This is my 3rd mustang and it's my third set (bought them with each one). Wouldn't have it any other way.
![Screwy](https://themustangsource.com/forums/images/smilies/screwy.gif)
How did you swap out the third brake light without removing the plastic trim?
The only problem with those is that they're available only in clear, clear/red, and smoke. They'd look
on a Vista Blue Mustang. So far the people that have chimed in have gray or black Mustangs, which are perfect candidates for the smoked lens.
I'm looking for a nice clean look with less different colors on the car. I felt the red just jumped out at me. Soo, we will see. If not, I may have a whole set up for sale
Thanks sound wave for the pictures. I was looking for a Taco Bill write up and you handled it nicely
That's just my opinion of course! I like the LEDs but would prefer a red lens cover and a potted circuit board, but I could settle for just a LED cluster replacement. Ford's diffuser/reflector assembly looks very funky but it might work well even for a LED cluster. I'm not looking for blinding red light to come out considering the stock lamp doesn't seem to be extremely bright either.
Soundwave: Where's the load-down resistor? The resistors I see in the pic appear to be ones that reduce the input 12VDC to a voltage level suited for the individual LEDs.
not in the same category as tacobill, but you're welcome.
sound wave: Was there a specific reason you had to use a load-down resistor? Was it to trick the car into thinking your brake lights are fine?
hey since you are going LED as much as possible, have you changed out the map lights? if so, what did you do? i wanted to go with the one from moss, but i heard people are having the same problem with the lights being constantly dimly lit when off.
