SHR Honeycomb Blackout Panel
I just took delivery of my new SHR Honeycomb Panel and I realize how simple installation is, but I want to see how everyone else installed it. Did you use a certain technique to center it up and make it really precise or did you just eyeball it? Thanks in advance.
Justin,
I just followed the instructions and did three practice runs before the final try.
I had my son help me with another pair of hands to help steady the panel.
It came out fine, but I was very nervous during the final application.
It is extremely worth it.
Good luck.
RC
Good luck.
RC
Thanks for the reply, I eneded up using a method I found on the internet of taping scotch tape to the covers on the 3m tape at the edges and centering it up with just the center 3m tape. All I had to do after that was pull the scotch tape attached to the covers exposing the 3m tape on the edges and push on to attach.
practice runs are great , however I wish I did that was slightly off center but carefully removed receneterd and it worked out fine, keeping it straight or level would be the task , so if say an outer marker or sticks could be place on like 4 or 2 corners I think that would help.
TMDM
Sep 24, 2015 07:00 PM
JonathonK
Sep 24, 2015 06:31 PM
Evil_Capri
Sep 11, 2015 08:39 AM
