Shaker hood question
Old May 22, 2011 | 04:18 PM
2006stang's Avatar
What is the width of the CDC Shaker Hood Scoop? Could I also see some closeup pics of the scoop as well. Thanks
Old May 23, 2011 | 06:43 AM
D'prived's Avatar
The scoop part is 12" W x 15" L
Old May 23, 2011 | 09:20 AM
2006stang's Avatar
Thanks....I see a shaker in my near future.
Old May 23, 2011 | 08:39 PM
aircare84's Avatar
Here is a pic showing the full size scoop & plastic shroud & mine after trimming down.
Attached Thumbnails Shaker hood question-gt-095.jpg   Shaker hood question-gt-097.jpg
Old May 23, 2011 | 09:13 PM
ford4v429's Avatar
legacy Tms Member
that trimmed cover looks great to me- I always kinda worried about trapping heat around the intake- plus I like to see the engine
to the OP- I'm pretty certain all these setups use the exact same scoop- its a ford cast aluminum part made for the 03 mach1. there was a company making fiberglass shaker scoops, but Ive never seen one...
for ours, ended up getting a fang hood/shaker- but bolted the scoop to their 'mach1' blockoff plate. it still blows thru the hollow hood chamber to their airbox, but leaves more room under the hood (still hoping for a blower someday).
Had to mold some 'glass standoffs to the plate, mill some off the front bosses of the scoop, make a backing plate 'ring' / neoprene seal to seal the scoop to the hood, took a little longer than anticipated, but it worked out OK... and should clear a K-B
Old May 26, 2011 | 08:27 PM
azoufan's Avatar
I would have gone out and taken pics of mine, but it would be flat out over the top embarrassing compared to how clean those engine bays are. I hate you guys.
Old May 26, 2011 | 08:57 PM
STL-GT's Avatar
Definitely do it. Awesome mod!
Old Jun 11, 2011 | 07:30 AM
Kevin74's Avatar
Will this hood work if you have a factory scoop? I heard rumor that it wouldn't.........
Old Jun 11, 2011 | 11:38 AM
D'prived's Avatar
It won't cover the two rear holes that hold the scoop on. You would have to get them filled and the hood repainted.
Old Jun 13, 2011 | 07:57 PM
Wicker68's Avatar
STL-GT: where did you get the shaker with the "281" on the side? Did you trim out the plastic shield over the valve covers? What'd you use to trim it?
Old Jun 13, 2011 | 08:06 PM
D'prived's Avatar
Here...
http://www.autobadges.com/emblems/
Old Jun 14, 2011 | 05:47 AM
STL-GT's Avatar
On the badges, D'prived is spot on. Check out Autobadges at the link he posted.
On the shroud, yes I did trim quite a bit of it so it wouldn't hide the valve covers and trap all the heat underneath it. I basically taped off the line I wanted to cut, used a dremel to make the cut and used self-adhesive door molding around the edge to hide the cut edge. TacoBill has some great information on how he trimmed his shroud here:
https://themustangsource.com/f691/an...9/#post5539626
Old Jun 15, 2011 | 11:59 AM
Kluski's Avatar
I'll put a vote in for the shaker. I love mine! The Foose hood and the 281 emblem really add some style to it. I have not shaved mine down on the inside, but I like the look and have considered it.
Old Jun 15, 2011 | 06:20 PM
STL-GT's Avatar
Never seen a Shaker with a Foose hood before. Looks awesome!
Mar 30, 2021 09:29 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
yabutt
Oct 23, 2015 01:05 PM
Bryanh24
Oct 14, 2015 08:43 AM
MustangConvert11
Sep 30, 2015 08:01 PM
