sequential turn signals
#42
Originally posted by adrenalin@March 6, 2005, 6:02 PM
Gordon, that is correct and yes, the signals will keep sequencing, as well as hazzard lights until you turn them off.
Thanks for clarifying, John.
That is how I wanted them to work and I remember reading a while back it was not the case, now that everything seems to be worked out I'll order mine.
Thanks again!
#45
#46
I just ordered it yesraeday. Will report back when installed. Mark
Has anyone tried web electrics splice in kit for sequential turn signals? At $89 quite abit cheaper than their older one.
[/b][/quote]
Originally posted by brown412+March 18, 2005, 12:10 AM--><div class='quotetop'>QUOTE(brown412 @ March 18, 2005, 12:10 AM)</div><div class='quotemain'><!--QuoteBegin-DozerzPony@March 6, 2005, 11:46 PM
Good job! You won't regret it!
[/b][/quote]
#48
I'm not sure why you would even ship them back for a refund. I kept mine. That way if something goofy happens to these things in a few years I can easily swap back to original.
#51
I'm working on stopping the burst function. I found the grey connector.
I found the gray wire with black stripe. Not sure about the blue wire.
Is it right next to the gray wire. Its blue, but to me it looks like a pink stripe?
Help from someone that has done this. Thanks...
#52
Jeff,
I did this as well, and I agree it is tuff to pick out, I did it by process of elimination. I believe if memory serves that there are only 2 other dark blue wires, if you are unsure by a simple test light (around 8.00) and test it.
According to the pinout for the connector the gray/black wire is pin 46 and the blue/orange is pin 41 I'm going to try to attach the pinout in a doc format for you.
[attachmentid=15181]
#53
Thanks Gordon,
Pins 41 & 46 according to the chart says right & left front? There is several different pins that say right & left rear?
I used a multitester on the wires that I identified and got the needle to bounce back and forth when I turned on the signals. I guess I'm OK...
#54
#56
Thankyou...
I read all the posts before I started this and was still having difficulty.
I now have the wires run back to the trunk. Just waiting now to receive the Webelectronics $89 splice in kit.
#57
I just went to webelectronics web site, I just have 1 question. Do both "kits" do the same thing? I mean does the $89.00 kit and the $139.00 (After rebate) kit produce the same affect, only with more work on the $89.00 kit?
#58
that is what they told me. Same thing, just a little more work. I should have mine tomorrow.. I hope
#59
Queen Of Nascar
I bought the $139 (after rebate) and installed it today. It was very easy, but after you get the panels off and get in there, in my opinion the $89 one would be just as easy. He sends good instructions.
