Roush Hood Scoop
Old Mar 30, 2008 | 11:12 AM
mustang jack's Avatar
Roush Hood Scoop
Hey Everybody,
I am thinking about getting a Roush hood scoop this spring.Eventually getting shelby stripes also.Is the scoop easy to install???
Also any Pics of installs??
Where is a good place to buy the scoop?
Thanx,
Jack
Old Mar 30, 2008 | 12:00 PM
psfracer's Avatar
Easy to install, it attaches with 3m tape AND screws. They provide a templete on paper which you use to drill the holes.
Old Mar 30, 2008 | 12:57 PM
jadeuel's Avatar
I installed mine the day after my car came home, easy install just use the template and you will be good to go. I found my scoop had a slight variation from the template so I had to elongate one of the wholes to keep from forcing the scoop to fit the wholes and so it would lay good and flat. You definitely want to test fit it before you peel the tape and make the necessary whole adjustments as needed.
I would by directly from Roush and have them pre-paint it, unless you are going to do something special paint wise.
May 3, 2026 05:42 AM
09-gt/cs
Oct 15, 2015 10:03 AM
