Roush hood scoop
Old Jan 28, 2006 | 01:00 PM
lasalope's Avatar
Thumbs up
Hi guys!
I need some help.
Can anyone give me the dimensions (height, lenght and max. width) of the Roush hood scoop, please?
Thanks! :worship:
Old Jan 28, 2006 | 02:26 PM
GRAYPNY's Avatar
I didn't read the whole thing but maybe this will help.
http://www.roushparts.com/products/05/05pd...stallation'
Old Jan 28, 2006 | 03:36 PM
Thunder Road's Avatar
Roush isnt a bad looking hood scoop but looks so tiny on the 05s.. so do shakers for that matter.
Old Jan 28, 2006 | 06:10 PM
lasalope's Avatar
Nothing about dimensions.
Thank you anyway Rich!
Old Jan 28, 2006 | 06:21 PM
lasalope's Avatar
Maybe you're right, I have not decided yet if I'll go with the Roush hood scoop. I also prefer the CDC shaker, but in my country it will be a problem to
be legaly approved.
I don't know what to do... :scratch:
Old Jan 28, 2006 | 11:10 PM
RadBOSS's Avatar
Just installed one on mine. I think its plenty big and proportioned well for the car. Even more noticalble from behind the wheel.
1-5/8" H
16" W
25" L
Old Jan 29, 2006 | 06:58 AM
lasalope's Avatar
1-5/8" H
16" W
25" L
Thank you Paul!
Old Jan 29, 2006 | 10:49 AM
acadian's Avatar
I also agree that the Roush scoop dimensions are fine for the '05 hood. I had the Roush scoop and liked it a lot. One thing though... IMO you need stripes to make the Roush scoop look really good. Without stripes, it does look a little small.
Old Jan 29, 2006 | 03:19 PM
GRAYPNY's Avatar
So Ian I guess you don't like mine?
Old Jan 29, 2006 | 05:19 PM
RadBOSS's Avatar
Well there are exceptions to the rule to be considered.
Old Jan 30, 2006 | 05:05 AM
lasalope's Avatar
Ok guys...
I have ordered mine today!!! :banana2:
And will probably go with stripes.
Old Jan 30, 2006 | 08:00 AM
acadian's Avatar
Rich., I love your hood scoop. But you know how I feel about stripes. One of these days I'll talk you into it.
Old Feb 19, 2006 | 07:23 PM
praztek's Avatar
I finally got the Roush Scoop in the mail and had one question. Is the drilling really necessary or will the proper adhesion methods do the job? How fast would you actually have to be going for it to rip off the hood?
Thanks,
Mike
Old Feb 19, 2006 | 10:07 PM
RadBOSS's Avatar
Well tape can fail over time, particularly if there was an area that did not take. Over time water gets in and the area of disbondment increases. Drilling the holes is no biggie ... sounds like you may want to remove it later? While the scoop is a pretty good match to the hood, its not exact, so perfect contact is not always possible. My painter had trrouble with mine, so areas of the hood pulled away. he eventually had to remove the tape Roush used and put on his own. So far its sticking, but its bolted down too.
Old Feb 20, 2006 | 05:05 AM
porkster's Avatar
I would suggest going and buying some Good double sided tape too. The tape provided by Roush is not the best quality. I also got the Roush louvers and they were almost falling off with the tape provided. I took them off and put on some good tape, and they dont budge now!
Old Feb 20, 2006 | 08:55 PM
jason929rr's Avatar
Does anyone put a screen of some sort so bugs and stuff doesn't get trapped in the scoop?
Old Feb 20, 2006 | 09:32 PM
RadBOSS's Avatar
Front of the scoop is blocked / blanked off
Old Feb 21, 2006 | 06:45 AM
acadian's Avatar
<div class='quotetop'>QUOTE(jason929rr @ February 20, 2006, 9:58 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
The Roush scoop comes with a solid plastic "grille" that blocks anything from getting in. You can make it functional like I did when I had mine. Just takes cutting a hole in the hood and replacing that solid plastic piece with a piece of wire mesh. I bought a piece of gutter guard at Home Depot and bent it using the stock Roush plastic piece to match the curve of the hood scoop. Then I painted it flat black and attached it to the scoop. I had planned to fabricate some sort of real ram air setup with some flat rectangular aluminum flashing or plastic tubing, but never got a chance to. What I did do though is cut a small hole in the hood insualtion blanket right over the air filter (there is actually a rectangular indention over it on the insulation. Of course, you need an aftermarket intake with a conical filter for this to work. But then I took out the insulation blanket fastener that was between the hood scoop and the intake filter. That way, when the air came in from the scoop, at least some of it was brought straight to the intake, rather than just filling up into the engine bay or between the hood and blanket.
Here is a pic (after my wreck) of the hood and scoop. You can see how it is functional.
Mar 30, 2021 09:29 AM
09-gt/cs
Oct 15, 2015 10:03 AM
