Removing The Rear Emblem
Old Dec 10, 2004 | 09:06 PM
1NewStang's Avatar
I need a bit of help.. Can someone tell me the best way of removing the rear Emblem for Striping purposes, And what is needed to put it back on.. The Guys doing my Stripes are the Guys that do all Graphics for the JBA SEMA show cars..But he does not remove the Emblems... JBA takes them off before he gets the cars...He's done a great job so far..All thats left to do is the Trunk..
Thanks for any help in this area..
1NewStang
Old Dec 11, 2004 | 05:44 PM
upstate's Avatar
My guy attempted but said it looked like it was going to break, so he went around it. Are there screws?
Old Dec 12, 2004 | 12:11 AM
superman112's Avatar
1NewStang
dude, I had the same question when I got mines striped a few weeks ago. No they are not screwed in, they are just glued there, i took mine off with a screwdriver, just be very very careful witht he paint job...trust me its worth it if you want a top notch vinyl job..
Old Dec 12, 2004 | 03:31 AM
wyldv6's Avatar
The rear badge and GT fender badges are attached to the car with double sided tape.
To remove, heat area with a heat source (hair dryer) use a thin piece of plastic (Blockbuster card will do fine) or fishing line.
You should know that both have alignment holes in the sheet metal, so in less your going to fill & paint the holes, I suggest leaving them on.
Put on the stripes and replace the tape on the emblem and reattach.
The first mod I did was replacing the GT rear emblem with a tri bar running pont off a V6.
Old Dec 12, 2004 | 08:40 AM
FordRacing's Avatar
Did you order the entire badge from ford or can you get just the emblem?
How much did the swap cost you if you dont mind me asking?
Old Dec 12, 2004 | 10:07 AM
1NewStang's Avatar
Wyldv6,
Thanks for the help.. I also have a new badge ordered just in case something goes wrong and this one breaks.. They are 25.00 bucks Also my service guy said he'd have it put back on at no charge.. if I needed
Thanks again
1NewStang
Old Dec 12, 2004 | 03:55 PM
wyldv6's Avatar
1New,
Your welcome for the info. I would hope for no charge since you can do it at home.
Ford Racing,
The cost is about $25.00 for the whole badge from Ford as 1New states, I found mine on ebay ($15) three weeks before getting the car. It only takes about half an hour to do it yourself. Paitence (sp) with the hair dryer and then cleaning the residue off the trunk lid is the most time consuming thing of the install.
Make for a nice little change. My next change is a aftermarket antenna, OEM is just to tall for me.
Old Dec 12, 2004 | 05:19 PM
Fordracing200's Avatar
I would put a rag under the screw driver so u don't scratch it, but don't use a block for leverage cause that will dent the lid,
Fords4Ever
Oct 30, 2015 09:07 PM
dblhelx
Oct 6, 2015 08:08 PM
seaclam
Sep 25, 2015 01:29 PM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
