removing the GT emblem, how far apart are the hole
I had my emblems sitting right here. 1 1/8 inch. One pin at the lower right hand corner of the G, the other at the top and further to the right, at the imaginary place where the G and T join. Both emblems are the same, so the passenger side of the car has the top one forward, the driver's side has the bottom one forward. I used dental floss (about 4 strands) and sawed behind the badge. (Cinnamon worked best
) This leaves a lot of residue, but it mostly just rolls off if you rub it with your finger. Use an adhesive remover to clean the area up. Now you got holes!
