Removing the front fender liner
Old May 24, 2006 | 10:47 PM
hpaddict's Avatar
Hi, I'm having some trouble removing the front fender liners in the wheel well. The plastic fasteners Ford uses are really cheap and I've stripped them. Any suggestions on how to remove them? Is it ok to just tug really hard at the fender liner to get the plastic fastener to pop out? Any tools you guys suggest I use? Also, where can I buy replacement plastic fasteners? Thanks!
Old May 25, 2006 | 08:51 AM
silverGTvert's Avatar
You should just twist the fastners about a half turn then use some needle nose pliers to pull them out. If you keep turning with the screwdriver you will strip them.
Fords4Ever
Oct 30, 2015 09:07 PM
seaclam
Sep 25, 2015 01:29 PM
DEPUTY62
Sep 12, 2015 11:12 AM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
