remove antenna
How do I remove the antenna from the car so I can put on my car cover? Dont really want to cut a hole in the cover so I figured if there is an easy way to remove and then reinstall antenna I would go ahead and do that.
just use a wrench on the square part down at the bottom of the antenna. Make sure the wrench fits that piece or it won't go on if it's to small and if it is to big the wrench will spin and not turn the antenna. Turn it counterclockwise. Hold on to the antenna with one hand so it when it gets loose it wont fall and chip your paint. Getting it back on should be a breeze. Need any help with the cover? I made banana pudding today.
Antigini-GT/CS
10/5/15 09:43 AM
9/10/15 12:44 PM
