Lots Of Choices in the Aftermarket These Days on The Standard S-197 Lamps! My Shelby Being Different Choices are Quite Slim & Spendy. Anyhoo Consider Making Your Own Less Lens If You Can Find a Friendly Fit From a Sourced Capsule & Oem or Aftermarket Enclosure! Hot Rodding is About Overcoming and Fabricating What You Need! Don't Know What Diameter You Need But Some Retrofit Motorcycle Capsules May Work! Anyhoo The Link Is Just To Show What a Lens Less Capsule is Like! And of Course Other Variations Are Out There!
Had A Thought! Realize When You Have FRESH Enclosures Yo Do Get More of a Sunken Look as Illustrated By My Then Both New Gt/CS & Gt-500, As The Lens Get Discolored & Aged it Really Takes That Look Away So a Fresh Set of Lamps Painted Inside Would Give a Much Closer Look To the Raxiom's Just More Food For Thought!
