Question on 18" wheels
just purchased a set of 255/45/18 in front and 285/40/18 in rear with Nitto 555... that setup was the closest diameter to stock... did i kill performance?? or am i ok?????
you should be ok going up 2 inches in wheel size with a little wider tire doesn't add all that much unsprung weight but look on the bright side you'll have more traction
