Put Fogs On My V6
Old Feb 27, 2005 | 06:43 PM
Grimlock's Avatar
Here's my V6 after adding foglights and 17" Bullitt wheels. I'll get better pics sometime when it isn't raining.
Old Feb 27, 2005 | 07:09 PM
Skarfunkly's Avatar
thats AWSOME! did u use the lights from wallmart like mr.wick?
Old Feb 27, 2005 | 07:11 PM
Skarfunkly's Avatar
o an how do u trn them on? how did u wire them to work?
Old Feb 27, 2005 | 07:15 PM
Grimlock's Avatar
Yep, those are the Walmart lights Mr Wick found. I also found the wireless switch and wiring harness at Walmart. Total for everything was $50.
Old Feb 27, 2005 | 07:38 PM
38special's Avatar
They look good.
Is that a 5.0 in your driveway?
Also, are the lights slightly smaller than stock GT?
Old Feb 27, 2005 | 07:55 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Wow, I love the bullit wheels on the v6!
Old Feb 27, 2005 | 08:57 PM
holderca1's Avatar
How exactly do you turn them on and off? I wasn't clear what you meant by the wireless thing you were talking about, I did see that you can get the headlight/fog switch from the GT on ebay.
Old Feb 27, 2005 | 09:01 PM
slowjoe24's Avatar
SWEET RIDE!!
Old Feb 27, 2005 | 09:03 PM
Grimlock's Avatar
The wireless switch is actually a little key fob. The kit has a wiring harness that connects a receiver that you mount under the hood to your power source and lights. Using this, you don't have to run any wires through the firewall. Works great.
The lights are 5", so they are smaller than GT lights.
The 5.0 is a 93 GT Convertible.
Old Feb 27, 2005 | 09:04 PM
Zc527's Avatar
nice...if I saw if driving down the road, I wouldn't be able to tell it was a v6!
Old Feb 27, 2005 | 10:24 PM
flight96's Avatar
Great job !! We should start a club I like the way the smaller foglights look! Here's a pic of mine...
Old Feb 27, 2005 | 10:33 PM
Skarfunkly's Avatar
anyone have the specifics on hwo to do this? i need to write it down for when i get mine
Old Feb 28, 2005 | 06:27 AM
Grimlock's Avatar
Looks like we were doing the same thing this weekend, flight96. I agree, the size seems just right for the grille.
Old Feb 28, 2005 | 06:30 AM
Mirakaski's Avatar
That 93 5.0 looks sweet!!
Old Feb 28, 2005 | 07:33 AM
jsheehan's Avatar
I find it kind of funny that you only see the right rear corner of the car and automatically know that the car looks sweet.
BTW, this seems like an excellent mod for us V6ers. I'm going to have to give this a try eventually.
Old Feb 28, 2005 | 08:05 AM
Mirakaski's Avatar
Its got a 5.0 !!! Its sweet....
Old Feb 28, 2005 | 08:32 AM
TampaBear67's Avatar
OMG! That Looks SCHWEETT! And they Look Factory Installed too! hey Look So Right on the V6! Ford Needs to take Note! The Smaller Diamater Lights Fit the V6's personality perfectly.
Old Feb 28, 2005 | 12:40 PM
flight96's Avatar
Posted By Skarfunkly
OK...Heres what I did.
I got the Blazer C120 lights. Got 2 hole saws, one 5" and one 4 3/4"...Heres is where you will benefit from my mistake...DON"T use the 5"...Its too large. Use the 4 3/4" Its perfect. I drilled the holes while the grille was still in the car. It was easy to get the alignment right, I just went by the honeycombs and measured from the outside of the grille. After I drilled the holes I took out the grille...Be careful when you do this!! Take your time,be patient. The clips come out easy once you get the hang of it. If you can get your hand behind the grille, just pull up on the tab, and GENTLY pull on the grille with your other hand...you will feel a slight pop....move on to the next tab...Again..be patient..I can't stress that enough. :nono: After I got the grille out I placed the lights in the holes with the mount side up. I did it this way for easy access to the wiring as well as they seemed to sit better that way. Next I used an epoxy urethane rubber repair kit that we use for repairing plastic/rubber bumpers. Its a 2 part epoxy that sets up fast and very simple to use.(I forget the name right now, I will post it when I go to the shop). I did drill one hole through the grille and into the mount on each light casing, just for piece of mind. Using blackhead flat screws. You can't see them unless your about 2 " away from the grille and looking for them. The whole process took me about 2 hours and cost me less than $ 60.00 Cdn. I haven't finished the wiring yet, im still deciding how I want to do it...switch or remote.
I hope this helps anyone interested in doing this mod. I think it looks great. If you want more info please let me know...If I can help ya I will!! GOOD LUCK !!
Old Feb 28, 2005 | 02:35 PM
psychen6's Avatar
Hi,
Thanks for all the info.!
I went to Walmart today, and saw the utility lights. Was going to get them, then realized that I didn't knew what else I needed! I noticed you mentioned a wiring harness and also a wireless switch. What do these things look like? I looked around, but I saw nothing that I could imagine being either of those things. Do you remember the actual name of the products?
Thanks for your help!
Old Feb 28, 2005 | 03:40 PM
Donna's Avatar
Queen Of Nascar
That looks great. Thanks for posting your pics.
