pulled the trigger on razors 20x9 now need tires...
Old 12/20/07, 05:33 PM
PATAN's Avatar
Talking pulled the trigger on razors 20x9 now need tires...
Hi guys, I finally made a decision of buying the shelby razors (grey ones) on tire rack
20"x9" 40 mm offset.
now I was thinking about the tires, I am going to get them more than likely form discount tires.
I've been thinking about these options, but I am open to opinions since you guys already purchased rims and tires...
option 1 - 265/35 20"ZR Nittos NT 555 all around
pros: cheaper, can rotate all 4 of them between them total cost of tires: $708
option 2 - 265/35 20"ZR Nittos NT 555 front / 275/35 20"ZR Nittos NT 555 rear.
Pros: wider on rear, 6mm taller behind. cost: $880
option 3 - 265/35 20"ZR Nittos NT 555 front / 285/30 20"ZR Nittos NT 555 rear.
pros: even wider on rear, but LOWER 14mm smaller total. will help with my retarded 3:31 rear end also to lower acceleration times I guess.. cost: $892
265's 694mm tall
275's 700mm tall
285's 680mm tall
the diff is less than 200 bucks.
I guess I will have to install sensors and maybe they'll charge me for putting them together and balance them...
Any feed back will be appreciated.
the closest fit to original, would be option 1... but again, if I am spending this much, it is not to look original..
I should be receiving the wheels from tire rack tomorrow...
Thanks!
Patan.-
Old 12/20/07, 06:11 PM
I lust for a M24
05GT-O.C.D.'s Avatar
I like Opt 2!
Old 12/20/07, 08:10 PM
rocket88's Avatar
depends on how much and how you drive. For me, the ability to rotate was most important, so I went with 265/35 on all 4. A slighty taller tire in the rear would look better, I must admit.
Old 12/20/07, 08:19 PM
PATAN's Avatar
I actually do a lot of miles ... put over 20k miles in 1 yr...
Old 12/20/07, 08:29 PM
I lust for a M24
The question isn't how much do you drive... it's how often do you rotate your tires. Me, I'm lazy... (opt 2!)
Old 12/21/07, 12:03 PM
PATAN's Avatar
what do you guys think about the 40mm offset?
I kind of liked them better with 24mm offset, but i heard the 40mm was made specially for the 05+ mustangs...
for the ones that have already these wheels, could you put a few pics here to see them? specifying the tire and wheel size and offset?
Thanks, as soon as I have mine on I'll put some pics myself!!
I am guessing option 2 also...
put some comments fellow mustang fans!
Old 12/21/07, 02:59 PM
touring's Avatar
you have pics of those 2 off sets?
WayneA's Avatar
You can get away with the 265 or 275 but not the 285 on a 9" wide rim. Nitto recommends a 9.5" rim for both the 265 & 275. If you must, go with the 265 on all 4 sides.
You could always send them back and get a set with 9's in the front and 10s in the back. Then you could go to a 295 in the rear.
Old 12/21/07, 03:01 PM
rocket88's Avatar
My setup is +24, Dunlop SP Sport 8000 265/35/20, Eibach pro kit springs.
Old 12/21/07, 03:08 PM
Tboned's Avatar
Here are mine..40mm offset and Steeda Ultalites...255 tire
Old 12/21/07, 03:16 PM
8905GT's Avatar
You barely notice the car in that second pic with that cute little dog there, noce photo work!
Old 12/21/07, 04:02 PM
Tboned's Avatar
nobody's ankles are safe...
Old 12/21/07, 04:42 PM
caligrn's Avatar
im going to go with some 20s, was always against them and would have been happy with 18s with lots of rubber but i couldnt pass up a deal on the 20s. my thing is, looking at the pics the tires dont seem to have much of a sidewall, im not a big fan of not having a decent sidewall ... any help on tire sizes would be greatly appreciated. thanks in advance
o yah 20x9 btw on all 4 corners
Old 12/21/07, 08:05 PM
Tboned's Avatar
I'd go with 265's if I could do it over again...255's are what's recomended by manufacturer, but litttle extra meat of the 265 looks better.
Old 12/22/07, 04:56 PM
SStang's Avatar
Then get 40 series tires. I'm not sure 265-40-20 is a common size, but 255 and 275 are widely available.
Old 12/22/07, 05:25 PM
ssstang67's Avatar
Hey TBone are yours silver or gunmetal? How do they match the satin silver of the car in person?
Old 12/22/07, 10:44 PM
PATAN's Avatar
mann real nice wheels, I am very happy I got them
I guess I'll have to go 265's all around?
mine are gun metal, not silver or chrome, I think they'll look nice in my white pony.
nice pics man!
those 2 cars look like twins
Old 12/23/07, 02:17 PM
PATAN's Avatar
one other question, the 265's are 99w and the 275's are 102w what does this mean?
I checked the Nitto web page, true the max I can go on these wheels is 275/35/20
I guess optin 2 will be the way to go
can't wait man!!
Old 12/23/07, 07:58 PM
05SatinGT's Avatar
Here is my car with 20" x 9" Shelby Razors +24 mm offset and Nitto
extreme 555 275/35 20 tires. I wanted a little extra sidewall .. car is also lowered with Saleen srpings. No rubbing at all.
Attached Thumbnails pulled the trigger on razors 20x9 now need tires...-pict1747.jpg   pulled the trigger on razors 20x9 now need tires...-pict1746.jpg
Old 12/23/07, 08:08 PM
I lust for a M24
That little bit of extra sidewall makes all the difference.
Quick Reply: pulled the trigger on razors 20x9 now need tires...
