Painted Stripe Removal?
Old 1/3/12, 04:42 PM
ThatMattGuy's Avatar
I dont know, but doubt it would be that expensive...you'd still need to tape/peel/test adhesion on the rest of it to be sure its got a decent bond(but looks like just poorly cleaned around light cutouts before it was painted). might be worth asking a bodyshop to look into.
I had a 81 dodge pickup(put a 396 chevy in it no less) that was over cleared, that truck polished up better than any vehicle Ive ever had, still looked great when I got rid of it 10 years later... it was a dark brown metallic with gold stripes- sounds ugly but it looked pretty sharp- and after clearing the stripes were smooth edged, easy to wax, etc...
just gotta be sure the existing(remaining) black has enough adhesion to stay put...once sealed *I think* it should not deteriorate/lift any more- but youd need to be pretty certain its holding fast before 'setting it in stone' or a bigger problem might arise later...
Alright, well I'll let you guys know how it goes...
Old 1/3/12, 06:59 PM
boss man's Avatar
Location: NJ. Waiting for our Gov. to be held accountable for his actions>>>Jersey Broke
If the blue is factory paint (baked on Enamle) then you can use laquer thinner without hurting the paint. I have a 2012 Boss and removed the decal from my hood and had a major problem with glue. I consulted a body shop and the laquer thinner was the fix. I used about a pint of thinner without any problems. Do a test area under the trunk just to be sure. Without the clear those stripes should bubble up and be removed with ease.
Old 1/3/12, 07:04 PM
THANK YOU! That sounds like an easy solution! I'll check it on the underside of the trunk tomorrow, and I'll post what happens!
3/30/21 09:29 AM
Cobiecane
10/23/15 08:44 AM
10/2/15 01:00 PM
GLOCKer
9/28/15 05:20 PM
UOP Shadow
9/27/15 07:24 AM
Quick Reply: Painted Stripe Removal?
