New stripes :D
Thanks alot . Yah i did them myself. The vynil is really easy to work with once you wet the surface with water and a little dishwashing soap. Use painter's tape to guide you with the alignment, cause regular masking tape will slide off when it gets wet with the water solution. A blow dryer or a heat gun will be a nice tool to have also, buy the heat gun at home depot and return it for a refund at the store after you're done installing the stripes
