New Rims and Tires
I think the black looks good, but they stick out so much in the rear, it gives it dune buggy look, IMO. :duuno: What's the offset and size of the wheels? Of the tires?
Just my opinion. As long as you like it, that's ALL that matters.
18x10 +30mm in the back. 18x9 +12 mm in the front. 285/40's in the back. 255/45's in the front.
My rear axle is a 1/4" off center towards the drivers side. Didn't notice this with the stock tires. That's why the driver side sticks out so much.
Have to get a spacer to kick the right side out more. I really like the look.
Mine was also off center to the left. I also didn't notice it until I put on wider wheels & tires. You may want to see if your dealer can slide the panhard bar over a little. Mine was able to do this and got it almost perfect.
Thanks for the sizes. It's that +30mm offset combined with the 10" wheels that's causing them to both stick out so much.
Rampant,
This is just a guess, but I'm thinking that white oval is a side marker turn signal light. If you look at Euro cars over here )BMW, VW, etc.) they all have a light between the door and the front tires, and since Kyle's in the UK, I'll bet they require them also. Is that close, Kyle?
Originally posted by jayguy@August 29, 2005, 10:18 AM
Rampant,
Rampant,
Yea, I understand about them sticking out. Didn't really want that either, but it looks so good in person.
Much more aggressive.
Rando
8/25/21 11:12 AM
