New rims for AM
Originally Posted by Corstang427
Also do I need to flash my car to compensate for the larger tires?
Originally Posted by B1GP1MP1N
If the height of the rim and tire are close to the original size I would say no you don't. Your speedometer might be slightly off. There are several calculators on the web that will tell you the % of size difference. Use google or search these forums and I am sure you can find one.
Originally Posted by Kevin509
Car looks great! 20's? Are you lowered at all?
So when my tires came in they had a sticker on the boxes saying they were filled to 44psi and should be adjusted to obtain good tread wear. The max on the tires is 50psi. What do I set them at??
I'm currently running 255/35/20 in the front at 36 psi and 275/35/20 in the rear at 34 psi and I like the ride quality at these pressures. My tire shop recommended I run them at 40 psi , but that's to harsh a ride for me. You want to make sure you don't go too low , I was running a previous set of KDW2's at 32 psi in the front and 30 psi in the rear and that was too low. The tire wear and the ride were perfect , they had 18K miles on them and still looked new. However because the pressure was too low , the tread started to separate with hair line cracks on the edge, so make sure you don't go too low. I read somewhere one time that a rule of thumb was 2 psi above OEM pressure for every inch increase in wheel diameter ...
