My Cervinis Concept Hood Flutters At Speed.
Old Oct 13, 2009 | 06:10 PM
NJ3's Avatar
NJ3
The passenger side of my new Cevinis Concept hood flutters bad at highway speed. I've talked to Cervinis many times about this and the keep telling me to adjust that hood stops. Been there done that and the hood is no better.(THEY ARE NO HELP) I took it back to my body shop and they came to the same conclusion I did, I got a defective and warped hood.
Anyone else have issues with a Cervinis hood? I thought they were supposed to be the best.
Should I just drill the **** hood for hood pins or let my lawyer handle it?
Here are a couple pictures with the hood down and not latched. Clearly the passenger side sits an inch higher than the drivers side.
Old Oct 13, 2009 | 06:39 PM
Dougxox's Avatar
My hood fluttered at high speeds, 100+, I am opting for the hood pins. Fiberglass is a tough one to work with keep it flat and level with out some more substantial sub bracing. Get the hood pins and go with the look and far better way of securing the hood.
Old Oct 13, 2009 | 07:02 PM
NJ3's Avatar
NJ3
Thanks, that helps. I guess pins would have the least impact on my wallet.
Old Oct 13, 2009 | 07:27 PM
Dougxox's Avatar
That and they look cool too !!
Old Oct 13, 2009 | 08:44 PM
Monkeygrits's Avatar
Maybe its just the pic but the drivers side looks to be too far back as well. Hood pins are the safest route. Over at my cougar club they have had a fiberglass hood or two go into the winshield without pins installed.
Old Oct 13, 2009 | 09:09 PM
nitecrawler27's Avatar
make sure that the 2 rubber mounts are leveled. I had a similar problem and i fixed it but just lowering one of the rubber mounts
Old Oct 14, 2009 | 05:49 AM
I can't help other than say hood pins also. Please post a pic of the whole hood/car. Is that the mach 1 hood?
Old Oct 14, 2009 | 02:39 PM
mustangpowers's Avatar
i have the cervinis ram air hood and never had any problems, i would get hood pins myself, a lawyer will be a costly long process that might not get you anywhere. JMO
Old Oct 14, 2009 | 02:57 PM
NJ3's Avatar
NJ3
Thanks for the responses. The hood does sit back a little on the drivers side, I can try to adjust that as well. As far as the rubber stops are concerned I adjusted those as per Cervinis instructions.
Here's a quick pic, I have it covered and I think I'm going to put a GT grille with fogs back on, The Bullitt grille just doesn't seem to fit the look.
Attached Thumbnails My Cervinis Concept Hood Flutters At Speed.-2009_1006010001.jpg
Old Oct 14, 2009 | 03:12 PM
Dixie_Flatline's Avatar
Fiberglass hoods are notorious for needing pins in order to secure them: they are much lighter and more flexible than the stock hoods. You're right to want to do something about it, it doesn't take much for the stock latch to fail and find yourself with a freshyly horizontally creased hood.
Didn't Brad post a thread in the past two weeks or so on the main 2005-09 page about hidden pins for aftermarket hoods?
EDIT: found it. Was in Exterior Mods, page 2 or so:
https://themustangsource.com/showthread.php?t=477292
Old Oct 14, 2009 | 03:47 PM
chad05gt's Avatar
Adjust snubbers on each end, you may need to adj. hook as well.
You dont NEED hood pins.
Ive been running my Concept hood for over 3 years, at well over 130 ( at Hennessey track in Sealy during 60-130et events ), no flutter.
Old Oct 14, 2009 | 04:07 PM
NJ3's Avatar
NJ3
I thought about those but you have to use hood struts with the hidden pins and I know some people have issues with struts on fiberglass hoods.
Old Oct 16, 2009 | 07:39 AM
Dougxox's Avatar
Have had struts on my hood since i got it, no problems. It ( the fiberglass hood ) is heaver than the factory Alum. hood and still use the prop rod at shows and when working on it for any length of time.
Old Jul 12, 2010 | 08:56 PM
BlueSkyVert's Avatar
How do you adjust them? I have awful flutter at 75 mph and above
Old Jul 13, 2010 | 12:23 PM
NJ3's Avatar
NJ3
They raise as you turn them CCW and lower as you turn then CW. You can also loosen the two bolts that hold the hood latch and lower the hood latch to increase downward tension on the hood. Just don't make too many adjustments at one time.
Old Jul 13, 2010 | 01:40 PM
So should I raise or lower them? What did you end up doing, and did it work?
Old Jul 13, 2010 | 01:47 PM
NJ3's Avatar
NJ3
I raised the outer stops to the point where the front corners of the hood where raised above the fenders, it looked lame and the hood still fluttered. I made all adjustments as per Cervinis tech support including installing washers between the hood and hinge, which only made the rear of the hood higher than the fenders. I only installed pins as a last resort.
Old Jul 13, 2010 | 01:48 PM
Sorry to hear that! I reaaaaaally don't want to install them.
I am about 20 minutes from Cervinis, I wonder if they would give it a shot.
Old Jul 13, 2010 | 01:53 PM
I just sent them an email.
Wonder how much I could get for this hood, could make the switch to the aluminum Foose hood instead.
Old Jul 13, 2010 | 02:15 PM
Doogie's Avatar
The Foose hood is a very nice piece. Even my painter who does a lot of aftermarket hood painting said it was one of the easiest hoods he has ever painted. And with a $600 price at CDC for a pre-painted Vista Blue Foose hood, you can't go wrong!!
But I do get a little flutter with the Foose hood as well, but think that is due to my open Roush billet grill.
