Looking for some lightweight Wheels - Help please
Old Sep 20, 2008 | 07:53 AM
Gibbo_UK's Avatar
Hi there
Currently am looking for ways to drop some weight of my car and increase performance by doing so.
Car is a Saleen SC281 with 480RWHP.
Currently running 20x9" and 20x10" Saleen Chrome wheels, anybody know how much these weigh? They are **** heavy!
Am looking for something lightweight, but needs to clear my Shelby GT500 brake kit, ideally 18" in size and want as light as possible.
I love the look of the Steeda Black Pentar wheels, but am unsure on the weight, ideally aiming for 20lbs or less per wheel.
Anyone here running Pentar wheels?
Old Sep 20, 2008 | 02:26 PM
Gibbo_UK's Avatar
Hi there
Well weighed my Saleen wheels and tyres today.
Saleen 20x10" wheel weighs 38-40lbs
Pirelli 275/40/20 weighs 32lbs
Total combined weight 72lbs
So definetely need something lighter, but can anyone point me in the direction of a decent wheel shop please online and one which list wheel weights.
Old Sep 20, 2008 | 03:03 PM
Ministang's Avatar
I'd take a look at Enkei RPF1's in 18" sizes, they have them in 18x9 and 18x9.5 and they weigh 17-18 lbs each. Also take a look at tire weights. You don't want to compromise grip more than you have to, but the same size tire can vary in weight as much as 5+ lbs from one model/brand to another. Edge Racing and Tire Rack both list wheel and tire weights on their sites.
One of the wheel/tire combinations I'm considering for my '08 is the 17x9 Enkei RPF1 with 255/45 General UHP tires for a total weight of 39 lbs per corner (stock is around 50 lbs per corner)
Old Sep 20, 2008 | 05:27 PM
frdtch05gt's Avatar
CT-R 18" wheels will clear the Shelby brakes. They weigh 26 pounds each, significantly less than your current wheels. Looks like they only have chrome 18x9's available right now, unless their website isn't updated. http://www.ctrwheels.com/chrome.htm
Old Sep 21, 2008 | 03:23 AM
Gibbo_UK's Avatar
HI there
Yes I do like the Enkei RPF1's and the RP03 I just wish they came in black, could they painted black and look professionally/factory done?
Old Sep 21, 2008 | 03:46 AM
Hatchman's Avatar
I like the CTR wheels, much lighter than the usual 18".
The Chrome may be too much bling for most, but stock center caps fit on them great!
Old Sep 21, 2008 | 04:06 AM
Gibbo_UK's Avatar
HI there
The CTR wheels are not that light as they are 26-29lbs each, am trying to hit closer or less than 20lbs ideally.
Old Sep 21, 2008 | 05:15 AM
Hatchman's Avatar
Originally Posted by Gibbo_UK
HI there
I just searched and found three different 18" wheels under 20 lbs:
http://forums.bradbarnett.net/search...earchid=942749
Old Sep 21, 2008 | 09:43 AM
Gibbo_UK's Avatar
That link dont work for me, can you tell me what you searched under please as I am not having much luck.
Old Sep 21, 2008 | 10:59 AM
jedikd's Avatar
Take a look at these threads:
http://forums.bradbarnett.net/showthread.php?t=470108
http://forums.bradbarnett.net/showthread.php?t=461952
Old Sep 21, 2008 | 05:22 PM
Gibbo_UK's Avatar
Hi there
Found these Enkei RPF1's in back:-
http://www.rx7club.com/showthread.php?t=745377
Can you guys click the link please and check if they will fit on our Mustangs from the details on that link?
Thanks!
Old Sep 21, 2008 | 07:09 PM
x96283's Avatar
kazera kz-a's in 18" inch.
they clear my gt500 brembos, are pretty darn cheap on tirerack.com and have a simple satin black option, with polished lip.
like you, i'm breathing through a saleen sc and the 18x9.5 width lets me run 285/40 series tires.
Old Sep 21, 2008 | 07:56 PM
Ministang's Avatar
Hi there
Thanks!
Yes, those should work, the bolt pattern is correct and the offset is ok too.
I've seen various sizes and fitments of the RPF1 in black over the years, but apparently they aren't available in black in every size and fitment.
Old Sep 22, 2008 | 07:01 PM
StangFreak's Avatar
Hi there
Thanks!
http://www.tirerack.com/wheels/Wheel...oModClar=Coupe
Try these, very similar to the Wed Sports. Not as wide at 18x8.5/18X9.5 and 1lb heavier. You should still be able to run a 295 series tire in the rear even though it's not as wide.
CiniZter
25
Apr 28, 2016 05:41 PM
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
