INSTALL FACTORY HID HEADLIGHTS IN 05-09 MUSTANGS
Old Jul 20, 2022 | 04:59 PM
05stangkc's Avatar
Back in the Day this was a Popular Upgrade to the 05-09 Mustangs. This Process was Supplied My Marcello Canitano of Silver Horse Racing. It Used to be on his website as a Free Download but came down at some point. I also thought we had a Post on it Somewhere in My Old Gt-500 Conversion Topics. I asked him for a copy while emailing him on another Topic as I thought There still might be some interest in the Info. I do not know if The Ford Wiring Harness is Still Available or How Easy you can find a Radio Shack These Days But here is the Info None The Less. Use at Your Own Risk. Differences in Harnesses were due to These Parts Options.
UPDATE 07/21/22 Wiring Harness Obsolete. Be advised Ford Offered Different HID Harnesses For Certain Options. It is My Opinion That Sourcing a Used Harness from an Hid Car would be best Served By Getting a Shelby Harness for a Shelby and a Base/GT From a Base or Gt/ Harness. One Listed was Base G/T Cars. If I wanted to do this Upgrade I would Get Wiring Diagram of Halogen Vs Hid and See what was Different besides Actual Headlight Bulbs Pigtail. This is not a Mod for the Faint of Heart and could turn Bad real Quick.
EXAMPLE Below.
  • Fit Note: High Intensity Discharge Headlamp, Perimeter Alarm W/Intruder/Sensor, With
    Front Fog Lamps
SEE PDF.
KC
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 19, 2023 | 02:05 PM
05stangkc's Avatar
UPDATED WITH 2008 Wiring Diagrams! Also Shop Manual Section on Headlights!
Need Used Headlight Harness Out of Similar Car. Base For Base, Gt For Gt, Gt-500 for Gt-500, Just With HID'S
Check For Alarm, Pony Package Bullitt {Less Fogs} Etc.
Good Luck!
Mgb,
KC
Parts Reference Look At 14290 Harnesses
https://www.fordpartsgiant.com/parts...nsmission.html
Mgb,
KC
Old Sep 19, 2023 | 02:11 PM
05stangkc's Avatar
Wire Assy
7R3Z-14290-EB
Wiring Assy
Service Wire Harness May Contain Extra Connectors. Consult TSB 06-17-8 For Service Procedures
Fitting Vehicle Options:
8 Cyl 5.4L DOHC EFI S/C
ALUM
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-AA
8R3Z-14290-AA
Wiring Assy
Fit Note:
Less Anti-Theft Alarm, Less
Front Fog Lamps
6 Cyl 4.0L SOHC EFI
Base Number:
14290
Callout Name:
14290
8R3Z-14290-BA
Wiring Assy
Fit Note:
Less Anti-Theft Alarm, With Front Fog Lamps, With Front Fog Lamps #2
6 Cyl 4.0L SOHC EFI, 8 Cyl
4.6L SOHC EFI
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-CA
8R3Z-14290-CA
Wiring Assy
Fit Note:
Less Front Fog Lamps, Perimeter Alarm W/Intruder/Sensor, With Halogen Headlamp
6 Cyl 4.0L SOHC EFI
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-DA
8R3Z-14290-DA
Wiring Assy
Fit Note:
Perimeter Alarm W/Intruder/Sensor, With Front Fog Lamps, With Front Fog Lamps #2, With Halogen Headlamp
4.6L SOHC EFI
Base Number:
14290
Callout Name:
14290
8R3Z-14290-EB
Wiring Assy
Fit Note:
Production Date:
06/2007-12/2007
ALUM
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-EC
8R3Z-14290-EC
Wiring Assy
Fit Note:
Production Date:
12/2007-02/2009
ALUM
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-FA
8R3Z-14290-FA
Wiring Assy
Fit Note:
High Intensity Discharge Headlamp, Less Front Fog Lamps
6 Cyl 4.0L SOHC EFI
Base Number:
14290
Callout Name:
14290
Ford 8R3Z-14290-GA
8R3Z-14290-GA
Wiring Assy
Fit Note:
High Intensity Discharge Headlamp, Perimeter Alarm W/Intruder/Sensor, With Front Fog Lamps
4.6L SOHC EFI
Base Number:
14290
Callout Name:
14290
8R3Z-14290-HA
Wiring Assy
Fit Note:
Headlamp
Production Date:
06/2007-12/2007
ALUM
Base Number:
14290
Callout Name:
14290
8R3Z-14290-HAA
Wiring Assy
Fit Note:
Headlamp
Production Date:
12/2007-02/2009
ALUM
Base Number:
14290
Callout Name:
14290
