View Poll Results: GT owners: Would you consider buying a replacement lower grille w/ foglights?
Yes
67
88.16%
No
11.84%
Voters: 76. You may not vote on this poll
An idea for aftermarket vendors. Replacement lower grille with foglights
#43
Mounted a set of PIAA's in the outer part of the lower grill, just drilled through the plastic and mounted it to an alum. plate and attached them to the bumper susport stud.
#45
Yes I like the Shelby set up ALOT with the Lower PIAA Fogs. But it dose not work
with the GT ft. end right?
Seems as if someone would just make the same thing and offer it for the GT right?
LINK TO PHOTO On Shelby Web Site.
http://www.shelbyautos.com/galleries...hc010-1024.jpg
#46
I really like this setup, I wish someone would make a replacement lower grill for the GT along these lines, but no it doesn't work with a GT. Although I'm curious as to whether a CS grill would work in the opening of a car with a CDC Aggressive Chin Spoiler, as the openings look like they'd be close in size.
#47
Those won't work with the aggressive spoiler either. Your best bet is to make something yourself. You can get cut some styrene to fit along one side of the foglights or just mount them freely. Here's a photoshop showing what I mean.
#50
Very nice now we need a write up and part #'s please? What did you use for the plastic ring around the fog lights? What lights did you use?
#52
Hey good job! The only thing I would have done differently, would be to mount the lights so that they are not as recessed to the rear. i.e. have them towards the front of the holes.
houtex
05-09 Exterior Modifications
12
8/26/15 10:54 AM
