Hood struts w/fiberglass hood?
Just bought this hood
http://www.americanmuscle.com/kaenen-cowlhood-0509.html One of my coworkers said that my hood will be a lot more brittle with the struts I was curious if this is true? And if I will have to be more careful? Use just 1 strut? Any help is appreciated!!! |
I ran struts on my Cervini hood. I don't see that you would run into any issues.
I use Redline struts on my Cervini's hood with no problems.
So far you guys got me @ ease! :D
prop rod only
Originally Posted by cdynaco
prop rod only
I ran my Cervinis Concept hood with MRT struts for a time. The main issue for me was that the hood was a little too heavy for the struts. Unless it was really warm, the pistons didn't have enough oomph to keep the hood up. So I've reverted to a prop rod for the past couple of years.
I gotta find my prop rod just in case :\
Just have your prop rod there for if the wind picks up. That's what my buddy does at shows when he walks away from the car. I know it kind of defeats the purpose of the struts, but it's added support.
That sounds like what I'll probably end up doing
(Post 6388017)
My struts are just some off the Internet cheap ones
These are great struts for the added weight of a fiberglass hood//http://www.281motorsports.com/product_info.php?manufacturers_id=&products_id=174 9
Fiberglass would be heavier than the stock hood?
Yes, fiberglass hoods are heavier than the OE aluminum hood.
+1 Your fiberglass hood is going to be heftier than the stock aluminum item.
My coworkers are all saying the fiberglass hood is lighter?
(Post 6387628)
http://www.americanmuscle.com/kaenen-cowlhood-0509.html One of my coworkers said that my hood will be a lot more brittle with the struts I was curious if this is true? And if I will have to be more careful? Use just 1 strut? Any help is appreciated!!! Awesome choice, that hood looks sick! I don't see a problem with running a hood strut kit with that set up. If you are worried about it, then the keeping the stock hood rod there is a great option. As far as weight goes, in most cases fiberglass hoods & Stock aliminum hoods are within a pound or so of each other. Let me know if you need further assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. Thank you for the business, we greatly appreciate it! - Dan |
Thanks AMdan
Does anyone know stock hood weight? I read on AM that the hood I ordered is 69lbs boxed.
