Help me find some new Wheels/Rims....
Old Oct 1, 2008 | 04:14 AM
Gibbo_UK's Avatar
Hi there
OK I am really struggling to find some wheels for my car and upto now wheels that met criteria turn out to be no longer made, as such were the WedsSport TC-005 and Axis Reverbs.
So this is what I am looking for:-
Wheel Specs
18x9" for the front with 18x9.5" or 18x10" rear
OR
18x9.5" all round
OR
18x10" all round
Meet this criteria
Fit with Shelby GT500 Brakes
Be lightweight as in sub 24lbs per wheel
Cost sub $400 per wheel
Now I love the style/design of the Steeda Black Pentars but those are 28lbs each which makes then no use.
Can anyone help please and as I am in UK please if you have any suggestions let me know where I can order them from.
Thanks in advance....
Old Oct 1, 2008 | 10:41 AM
MELLOWYELLOW06's Avatar
If you are willing to go up to 20's I have the perfect offsets now for the wheels on my car and tires. I can get them real good price also. Let me know.
Old Oct 1, 2008 | 01:01 PM
CO_VaporGT_09's Avatar
I say look on Tire Rack for the TR motorsports (don't know for sure about the brakes, though, look like they should):
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
18x9.5 18x9.5
Original Price:
Now 0% Off:
$0 (each)
$319
$319 (each)
Price:
$0 (each)
See price in cart
Offset: 45mm Backspacing: 7.16" Bolt Pattern: 5-114
Rec. Tire Size: 285/40-18
Weight: 19.0lbs.
Old Oct 1, 2008 | 03:11 PM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
An 18" wheel won't fit GT500 brakes
Old Oct 1, 2008 | 03:21 PM
Gibbo_UK's Avatar
The Shelby GT500 has 18" wheels as standard so those fit???
Old Oct 1, 2008 | 05:33 PM
I don't do trannies
I know it depends on the clearance, they say it won't fit most 18 my bad
Old Oct 1, 2008 | 05:37 PM
jedikd's Avatar
Check out Asa Ar1 on tirerack. 23lbs, $172. Only 18x9 but I'm running them with 275/40R18 all around. Not sure about Gt500 brakes.
Old Oct 2, 2008 | 10:48 AM
Rampant's Avatar
what about Steedas ($229)?
Not sure on the weight, but they say "lightweight" for whatever that is worth. :-)
http://www.steeda.com/products/pentar_silver_05.php
Old Oct 2, 2008 | 09:54 PM
My overall suggestion about the brake clearance issue is to call up TireRack directly. I know looking on the GT500 listing that wheel I put above wasn't included, only on the standard GT model, so maybe it is the brakes that make a difference. I think the reps at TireRack should have more info, though, overall to help answer the question. They do list the Gram Lights 57 for about $350 as fitting GT500, though, just not as good looking a wheel.
18x9.5 18x9.5
Original Price:
Now 14% Off:
$408 (each)
$349 Closeout
$349 (each) Closeout
Price:
$0 (each) Closeout
See price in cart
Offset: 38mm Backspacing: 6.69" Bolt Pattern: 5-114
Weight: 22.5lbs.
Old Oct 4, 2008 | 08:15 AM
JonCo's Avatar
Yeah GT000 rims can fit on a reg GT not the other way around. GT500 brakes need special rims to clear its brake system. If you have any idea of possibly upgradeing your brakes do yourself a favor and get ones which clear big brakes from the get go.
Old Oct 4, 2008 | 09:37 AM
Import-Slaya's Avatar
Enkei RP03's in 18x9.5 (+38 offset). Perfect fit and offset, tons of brake clearance, a little over 20 lbs. each, and under $350 each. (I have them in 17x9.5).
Attached Thumbnails Help me find some new Wheels/Rims....-enkei-rp03s.jpg   Help me find some new Wheels/Rims....-vir-pic-1.jpg
Old Oct 5, 2008 | 10:48 AM
Gibbo_UK's Avatar
Hi m8
You got any pics of them on your car please I can see? Can you get them in black?
Also you clearly like to make your car carve corners, well mine understeers badly and was looking at getting Steeda X5 Ball Joint and Bump steer kits, do you think those will help?
Old Oct 5, 2008 | 02:36 PM
frost181's Avatar
Axis Reverbs? I think they can accomodate big brakes. I know edmunds.com used em on a project car.
Old Oct 5, 2008 | 04:18 PM
Gibbo_UK's Avatar
Hi there
Yes those do fit but I cant find them anywhere. I need a set of 18x9.5" in black in the correct offset to fit my car, do you know anywhere that has them in stock?
Old Oct 5, 2008 | 04:28 PM
Originally Posted by Gibbo_UK
Hi m8
These are the only other pics I have with them on. (Looks like I have a lift because my driveway has a decent slope to it that jacks the suspension up on one side...)
As for the ball joint , that will help correct your front roll center. It *might* help with understeer if you can't get enough negative camber to compensate for the amount of roll you currently have.
The bump steer kit *might* help, if you are getting roll steer up front. It isn't easy to take these measurements, though. You basically have to remove your springs up front, then put the suspension back together. You then cycle the front suspension through its compression range, and take toe readings. If you get added toe-out during compression, you will get roll understeer up front (and roll oversteer if you get added toe-in during compression). Ideally, you want close neutral toe change during the compression range.
You could also be getting roll steer from your rear suspension. Do you have lowering springs? If so, have your corrected the rear lca geometry?
Staggered tires? Have you checked tire pressures?
What are your current suspension mods--this is the best place to start to try and help you out.
Attached Thumbnails Help me find some new Wheels/Rims....-new-wheels-1.jpg   Help me find some new Wheels/Rims....-new-wheels-2.jpg
Old Oct 5, 2008 | 04:52 PM
Gibbo_UK's Avatar
Hi m8
Did you post some pics as I cant see them?
I have PM'd you and yep the car is lowered by approx 1" all round with the Saleen racecraft springs.
I have tried different pressures, am I right in thinking that to reduce to understeer I need a lower pressure in the front than the rear. So say 34psi rear and 30psi front would help dial out understeer as I went from 34psi all round to 30psi front and 34psi rear but could not really notice any difference.
Old Oct 5, 2008 | 05:14 PM
Hi m8
Just added them--pm'd you.
Gigantor
May 11, 2023 07:31 PM
RCooke08GT
Feb 19, 2017 03:03 AM
