Heat Gun Setting on Vinyl Stripes ??
Anyone that has installed their own stripes or has some knowledge of the project; this question is for you.
When using a blowdryer (in my case a heat gun) do you have any idea of what heat setting should be used ?(approximate Degree)
The one I plan to use is variable from 250° - 1,100° with either 8cfm or 12cfm fan speed.
Just looking for a little info as I have had some serious trouble trying to install the front bumper pieces of my vinyl stripe kit without a heat gun.
Any tricks or tips would be GREATLY appreciated.
BTW the stripes are 12" wide if that matters.
The wider the stripe the harder the install. Are your stripes precut to fit? I assuming they are not if you need to use a heatgun. Anyway, the lowest setting should be enough. If you heat it up to much you can damage it. I find using a torch works pretty good to. A lot faster at quickly heating up an area. In most cases, you can just use a hairdryer. Vinyl does not require a lot of heat when trying to shape it.
I had to use heat to get my precut (BSM) pieces on the front and rear bumpers. I used my wife's hair dryer, mainly on the low setting. I don't have any idea of what the actual temperature was, but it was warm to the touch, not hot.
Here are more tips that may help, look at my post #5: http://forums.bradbarnett.net/showthread.php?t=47541
Tom
Tom
My installer did not use heat, but he did not wet the vinyl for the front bumper install. He went a little at a time and was able to stretch and pull where needed. Granted, he has done MANY of these. He did the front bumper in total less than 15 minutes.
I used a hair dryer to get the front bumper done. I started on low to be safe, but eventually had to get it up to high. I had it about 3-4 inches away from the vinyl. When I cranked it to high, I thought for sure I was going to melt a hole into them, but thank heaven I didn't...the bumper got pretty darn hot too!
Amazing the things I justify buying, just to work on my car
I know they are not expensive, I just have absolutely no other use for it.
![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
Looks like I will be investing in a blowdryer ![Frown](https://themustangsource.com/forums/images/smilies/frown.gif)
Amazing the things I justify buying, just to work on my car![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
I know they are not expensive, I just have absolutely no other use for it.![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
Originally Posted by tom281
Sure you do........blow dry parts of your engine compartment after washing it. Sometimes I use compressed air, but for shows I'll get 'er nice and dry with a little heat.
