Headlamp assembly removal
Old Sep 18, 2008 | 08:56 AM
RetroLane's Avatar
Anyone have any tips or instructions for headlamp assembly removal?
Will it come out without taking too much of the front off or are there other hidden bolts elsewhere?
Looking to paint the assembly sonic blue to match the body like others have done. Leaving the plastic cover on as I don;t want to run sealed beam lights.
Thanks,
Erick
Old Sep 18, 2008 | 09:03 AM
adrenalin's Avatar
You have to remove the front fascia. Then you can get to all the bolts that hold the headlamp in place.
Old Sep 18, 2008 | 09:13 AM
05YellowGT's Avatar
If you go onto the Steeda web site and look at their HID lights for our cars , there is a PDF on how to remove the old ones and install the new ones ...
Old Sep 18, 2008 | 09:14 AM
rony1976's Avatar
3 bolts hold the lamp in place, but as it was mentioned above, you can't remove it unless you remove your front fascia
Old Sep 18, 2008 | 09:52 AM
RetroLane's Avatar
Cool. Thanks for the info.
Since I'm still waiting on the title for my car, I figured I do some work on it during the down/wait time.
Erick
Old Sep 18, 2008 | 10:57 AM
FLAstangx3's Avatar
Uh, actually, in removing the front fascia.....once unbolted, just slide it forward. No need to actually remove it. You can then easily reach that "hidden" third bolt for the headlight assembly. Much better than taking the nose off and having to find a safe place for it, nor clumsly trying to re-instal.
Old Sep 18, 2008 | 11:25 AM
RetroLane's Avatar
Cool, even better. Thanks.
Old Sep 18, 2008 | 07:03 PM
MTAS's Avatar
Can the "hidden" bolt be reached from the bottom? Like where you reach in to pull the bulbs in the corner lights?
Old Sep 18, 2008 | 10:13 PM
Wardog 07's Avatar
Here's some during shots and a view of the "hidden bolts". Recommend the wife is gone when you do this or she will freak out when she sees the parts laying around the driveway.
PS - Also it's a good time to do the turn signal lenses to smoke/clear.
Old Sep 19, 2008 | 06:30 AM
RetroLane's Avatar
Thanks for the photos.
My wife's use to parts laying all around the driveway and house. I restore classic mustangs so there's always some car in pieces at my house.
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
GMAYS
Sep 10, 2015 06:19 AM
