GT 500 Shelby Conversion - Help/Advice Needed
Gentlemen I have read every thread on this topic I can find and here is what I believe to be a correct list of part numbers and quantites for a complete GT 500 exterior conversion. I am still missing the part number & quantites of the pins that retain the hood insulator. If anyone knows - please post. For those of you that have already performed this retrofit, please take a minute to review my list of parts and if I have made an error or if I am missing something please let me know. As always, your help is appreciated and I sincerely thank you in advance.
PS: I know the wheels are not included on this list. I won't be using the GT 500 wheels.
FRONT END
1 - 7R3Z-17D957-APTM Front Bumper Cover Assem. - Primed (Paint-to-Match)
1 - 7R3Z-8200-A Grille - Radiator
1 - 7R3Z-17K945-AA Grille - Lower
1 - 7R3Z-17626-AB Lower Valance Panel
2 - 7R3Z-15200-A Fog Lamps
1 - 7R3Z-14290-EA Fog Lamp Wiring (Shelby Headlight Wiring Harness)
1 - 7R3Z-13008-B RT Headlight Assem.
1 - 7R3Z-13008-A LT Headlight Assem.
1 - 5R3Z-16102-AA RT Splash Shield Front
1 - 5R3Z-16103-AA LT Splash Shield Front
1 - 7R3Z-8C291-AA Upper Sight Shield
1 - 7R3Z-17C882-A Bumper Foam IsolatorTotalsGCAT #Description - MountingQty
FRONT MOUNTING
1 - 7R3Z-17752-A Bracket - Bumper Mounting (RH)
1 - 7R3Z-8B455-A Bracket - Radiator Grille (RH)
4 - W711274-S439 Nuts
1 - 7R3Z-17753-A Bracket - Bumper Mounting (LH)
1 - 7R3Z-8B455-B Bracket - Radiator Grille (LH)
8 - W712930-S437 Rivets - Side Marker Lights/Bumper Brackets
4 - W705589-S Pin
10 - W302597 Bolt - Lower Valance Panel
10 - W302348S300 Nut - Lower Valance Panel
2 - W705436-S300 Rivet - Sight Shield
HOOD
1 - 7R3Z-16612-C Shelby Factory Bare Hood - Primed (Paint-to-Match)
1 - 7R3Z-16738-F Insulator - Hood
13 - YL8Z-16774-HA Retainer - Hood Insulator
1 - 7R3Z-16C630-AC LT Shelby Scoop Assem.
1 - 7R3Z-16C630-AB RT Shelby Scoop Assem.TotalsFord Part #Description - Rear SpoilerQty
REAR
1 - 7R3Z-6344210-BA Spoiler - Primed (Paint-to-Match)
1 - 7R3Z-17K835-BAPTM Rear Bumper Cover - Primed (Paint-to-Match)
1 - 7R3Z-16A550-AB Splash Shields
1 - 7R3Z-16A550-AA Splash ShieldsTotalsFord Part #Description - EmblemsQty
EMBLEMS
1 - 7R3Z-8A224-A Grille Cobra Emblem
2 - W709389-S438 Retainer - Cobra Grille Emblem
1 - 7R3Z-6342528-B Shelby Rear Name Badge (Decklid)
1 - 7R3Z-16098-B LT Fender Cobra Emblem
1 - 7R3Z-16098-A RT Fender Cobra Emblem
1 - 7R3Z-6342528-A Shelby Rear Faux Gas Cap
ROCKER MOULDINGS
1 - 6R3Z-6310176-AA Moulding RT
1 - 6R3Z-6310177-AA Moulding LT
FRONT END
FRONT MOUNTING
4 - W705589-S Pin
HOOD
REAR
EMBLEMS
ROCKER MOULDINGS
Looks like you are going for the full blown clone. I was gonna tell you that the hood insulator is not necessary. I didn't purchase one and I cannot tell any noise difference at all. Looks to me like all your part numbers are correct.
Parts Check Up
Check with KC at Clevenger Ford or clevparts@aol.com, he frequently posts and he knows his mustangs.
Good luck........
Good luck........
somewhere. Good luck on your conversion. Its not that hard to do, just
take your time doing it. Make sure you have a body shop that worth a
crap and you'll be on your way to conversion bliss.
Hello guys, sorry to hijack this thread but since my question dealt with parts I figured this would be the place to ask.
I have a list that I already had copied from this forum for the GT 500 front end conversion. The problem is that it contains two different parts that are not shown on tmcolgr's list. And likewise, he has two parts listed that aren't on my current list.
They are listed as different parts/prices when I checked on the web.
So which parts are the ones that I actually need?
Thanks for your help
tmcolgr's list:
7R3Z-17752-A Bumper mounting (RH)
7R3Z-17753-A Bumper mounting (LH)
my list:
7R3Z-17C861-A Reinforcement
7R3Z-17C861-B Reinforcement
WHOOPS, just realized that this thread ended last December!! Sorry
So which parts are the ones that I actually need? Thanks for your help
tmcolgr's list:
my list:
Diode Dynamics
Jun 12, 2018 03:26 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
