going to order rims/tires next week but have a question
Old Feb 14, 2006 | 11:02 PM
94tbird's Avatar
Should i do the 18x9.5's all around or do 18x8 in the front and 18x9.5 in the rear? whats more common and what do you think will look better?
Old Feb 14, 2006 | 11:06 PM
shatter's Avatar
I always run the same rim size in my cars so I can rotate my tires. I also don't run directional tread for the same reason. So, if you choose tires with direction tread then get whatever rim best fits your tire size selection.
Old Feb 15, 2006 | 08:08 AM
2006GT's Avatar
9s up front and as fat as you can in the back!
Old Feb 15, 2006 | 08:40 AM
94tbird's Avatar
they only come in 18x8 and 18x9.5
Old Feb 15, 2006 | 12:01 PM
94tbird's Avatar
bump
Old Feb 15, 2006 | 05:03 PM
mustangspeeder's Avatar
I think it really depends on how economical you wish to be. For looks I'd go 18x8 in the front with the larger in back. If you want to go longer without having to buy new tires, then do 18x9.5 with non directional tires.
I went for looks with 20x9 on front and 20x10 on back all with directional tires.
Old Feb 15, 2006 | 05:26 PM
94tbird's Avatar
im new to rims/tires. whats directional and non directional
Old Feb 15, 2006 | 07:26 PM
Enfynet's Avatar
Some tires have 'directional' tread on them so that swapping/rotating them from one side of the vehicle to the other would face them the wrong way. Some high performance and most winter tires are like this.
Personally, I'd go with the 9.5 all the way around. However, you probably don't want to run anything bigger than 275s up front. For the back you can go to 295s on a 9.5" rim. To have consistant sidewall on those staggered tire sizes go with 275/40,45 front (tire= .33" shorter, .75" taller than stock 756, 727rot/mi) and 295/40 rear (tire= .25" taller than stock 739rot/mi) [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
If you can find 265/45s for the front your tire heights f/r will be within 0.1"
Old Feb 15, 2006 | 08:51 PM
94tbird's Avatar
ok so i think im going to go 9.5 all around. should i do 275/40/18 all around as well, or should i choose the only other tire size that the website says fits for the front (245/45/18). the tires im looking at are the BF Goodrich
BFG G-FORCE KDW T/A
Old Feb 15, 2006 | 09:23 PM
Enfynet's Avatar
For 9.5 all around even 255s are gettin kinda narrow (10" tread). I have 255/45s on my 9" rims and they barely cover the lip.
See this post: http://forums.bradbarnett.net/index.php?sh...=0&#entry643680
Old Feb 16, 2006 | 09:30 PM
94tbird's Avatar
so do 275 all around then i take it?
Old Feb 16, 2006 | 10:51 PM
Enfynet's Avatar
For 9.5, yes, I'd go 275. The only thing with 275 is that the 40s are about 1/2" shorter than stock and the 45s are about 3/4" taller. Personally, I like the 275/45s because they fill the huge wheel wells better. [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Feb 18, 2006 | 06:59 PM
94tbird's Avatar
thanks for all the help. jsut ordered today. will have pics by friday or saturday
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
ssjbuu
Aug 28, 2015 08:55 AM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
CoyotePremium13
Aug 18, 2015 07:28 AM
