Eibach Pro and 20's?
Old Jan 10, 2006 | 09:08 PM
06TUNGVERTGT's Avatar
Thumbs up
I have my Eibach Pro kit but am thinking about doing 20"s when I replace my tires and new rims, thinking DD Bullits, my question is will it all fit or will I be stuck with 18's if I lower? :scratch: Sorry if this has been asked before
Old Jan 10, 2006 | 09:16 PM
GtStallion51's Avatar
20" wheels work well with the Pro-kit. I've had no problems. I think this has been asked before though ......
Old Jan 10, 2006 | 10:18 PM
rjuice's Avatar
do it it rides great
Old Jan 11, 2006 | 10:09 AM
mustangspeeder's Avatar
Mine work great with my 20's
Old Jan 11, 2006 | 02:05 PM
StangNut's Avatar
Once again, the clearance you will have has nothing to do with the size of the wheels you put on. It's the size of the tires. Assuming you want your speedometer to be accurate without having to reprogram it, you're going to use the same diameter tires as the stock ones. Which is 27.2".
Think about it. When the wheel gets bigger, the sidewall gets smaller. The overall height stays the same. (also known as the diameter)
Notice in the pic, only the wheel gets bigger... not the tire.
Old Jan 11, 2006 | 03:29 PM
Does the Speedometer read off the front or rear tires??
AJ_Trevino15
Sep 28, 2015 07:51 AM
TripleBlack14
Sep 17, 2015 07:48 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
killaz05
Jul 24, 2015 08:49 AM
