Clear turn signals available
#204
#205
#207
Originally Posted by 2005sonicgt
Did you get clear bulbs's and if so did you get them from the same site that got the clear corners from.
They are a bit pricey but you cannot see them until they illuminate.
#208
Originally Posted by mrkabc
NOT ANYMORE!!! The amber reflector is now built in and CANNOT be removed without disassembling (read: trashing) the housing.
Trust me, I speak from experience, unfortunately. That's why I call mine "mostly" clear.
The clears as we knew them before are gone now due to a DOT edict that required APC (and some other mfgs) to stop selling the all-clears.
JEGS doesn't have them. Tony's Performance Parts doesn't either. If you hurry you might find some all-clears on Fleabay before they vanish (or get ridiculously expensive).
#209
How about this place for clear makers?
http://www.slickcar.com/bigshot.asp?ProductID=5055
#211
Originally Posted by panamajk89
Do you have pictures of the new ones? I'm curious how they ruined the look.
NEW Clears
Do a search someone on here has already installed them on their Stang. It doesn't look as good as all clear, but they still look better than the full Amber ones.
#213
Here are the "new" clears installed on my 'Stang.
Don't waste your $$$ on "stealth" or even clear bulbs for the 194 side markers, that crap amber reflector will wash out that type of bulb.
I bought clear LED 194 bulbs in anticipation of an all "clear" lens, it was a waste of $$$.
Installation was very easy, just pull the wheel well cover, compress two plastic Christmas trees, and pull the lamp out of a slot in the bumper cover. You could almost do it with no tools required!
Good luck - hopefully you can still find some of the all "clear" ones out there - if not, you can bask in the knowledge that you are DOT legal...
#214
Found these here for a $99. What do you guys think??
http://www.v6mustangstuff.com/images/05blackturn.JPG
#215
Tony D
#217
I found a place in PA that has some I called and talked to them they are clear with no amber, also they qualify for their free shipping. Look here:http://www.mustangtuning.com/2005-tu...hts-clear.html
The only catch is the $119.99 pricing, but if someone wants them bad enough...
