cervini b2 chin spoiler
I took a few pics at the World Ford Challenge in 2006 in St. Louis. The parts had not been introduced yet, so it is possible that the spoiler I saw was a prototype, but since you weren't getting any other responses, here ya go...Hope it helps.
BTW, the entire B2 kit was just killer, and really captured the whole '69 Mach/Boss look perfectly. (I got lots of pics!) The front spoiler was very similar to the '69, but since the front fascia on the new Mustangs doesn't curve under as much as the '69, it did make the spoiler look rather like a cow-catcher. I think the design was great, but maybe they should have shaved it back a tad to keep it from sticking out so far.
B2 me too
i have had 2 so far. 1rst one was broken on a ramp, while cra was being serviced. Hangs lower than stock. DUH!
I replaced it right away. fit and attching is easy. I did add fender washer and bolts and lock nuts to keep everything locked down.
We have a different Cervini splitter (GT500 style) on the GT, so I can't give exactly what you want. I can tell you that we're satisfied with the fit and finish of their product, though. Good luck!
~Mike~
~Mike~
I also replaced the screws with bolts. The screws pulled out right away. Cervini's offered to send longer screws, I decided bolts with loctite on the nuts was the way to go. No more problems after I did that.
9/16/15 06:44 PM
MUSTANGfan2010
05-09 Exterior Modifications
8/15/15 06:42 PM
