Best bolt-in sequential kit?
I have a 07 GT and was thinking about installing a set of sequential turn signal kits. I want the kit that is the easiest to install/bolt-on and won't cause weird problems while braking or using the hazards. I'm not sure about changing the LEDs because I don't trust aftermarket housings as much as the OEM (UV weatherability of lens, waterproofness, etc...)
Any ideas?
Any ideas?
Web Electric Products, HANDS DOWN!!! They are a SNAP to install. I've had them for over 3 years in my car with NO ISSUES WHATSOEVER!! I got it down to 10 minutes per install now (installing them in all my friends cars).
no all simple plug & play remove rear panel , up plug harness from factory lights , then doing one at a time reverse the steps one at a time, , I may suggest before tightening back into place just try each light incase a bulb or something goes tapping some has that effect , then when you smiled and say YES put the lens back in place rear panel and yr done ! enjoy the mint !
I installed the WebElectric kit last week, it was a piece of cake. Remove the rear plastic molding inthe trunk (two hand turned screws and four snap out retainers). Remove the tail light bucket (three 11mm nuts), pull out the old harness, move the bulbs from old to new harness, reverse the preceding steps. I haven't run the wire to unsequence my brake lights yet, but intend to do so. Here are the WEP instructions for non-sequenced brake lights:
Notes for the STS-1M5HR/PW
Sorry the Web stuff is just the harness and sockets no lense replacement etc but once you break them free I clean them abit and get out grit etc so I get a good seal , BTW for like what a 30.00 ? core fee or what ever it was I just kept my factory ones to put back , should a need arise , then it's all very extremely simple. Honest.
Another vote for the Webelectric harness kit. I installed both sides in less than 30 minutes and they work perfectly. Just a simple wiring harness swap -- doesn't get any easier than that!
However - no, the hazards/brakes do NOT function as stock. Still, it is NOT a problem as when you apply the brakes they sequence rapidly once and then all 3 lights stay lit and do not continue to flash or do anything goofy. It's really an attention getter and probably a little added safety for if the person behind you is daydreaming. Look up a video of them on youtube and you'll see what I mean. Also, IMO nothing wrong w/ them sequencing w/ the hazards on - i figure you've got the hazards on to get people's attention anyway... right?
I'd imagine most companies are about the same with these? I have the CDC kit and they sequence exactly the same. I do actually like that with these harnesses when you brake you get all 3 lights, not just the 2. Very, VERY easy install.....unless you have a sub box by your taillight. That's when it takes a bit of times. I also kept my old harnesses, just in case.
I seem to not mind the brake lights fast sequen when appling them get a lot of people that notice the difference
http://s109.photobucket.com/albums/n...t=6000deb6.pbr
