Backup Camera..
Old Feb 2, 2015 | 08:11 PM
Fear's Avatar
Backup Camera..
Where have you guys put em?
I was thinking about putting it into the faux gas cap where the lock would be but not quite sure how i would do it.. I believe someone has done it here..
Also saw this on Crutchfield but not really a fan.. makes it pretty obvious..
http://www.crutchfield.com/p_074RVCL...PMB.html?tp=83
Old Feb 3, 2015 | 07:25 AM
berzerk_1980's Avatar
Wish I could help.
You probably know already but the factory camera is integrated into the spoiler, is that only on later models?
And the thread I read where someone did this had a GT500, since those don't have a camera option. Maybe that will help you search? I do remember that person installed it in it faux gas cap. If I recall correctly, there were instructions in the thread if you can find it.
Old Feb 3, 2015 | 07:27 AM
05YellowGT's Avatar
Here's a link to a write up on a head unit install with backup camera, it's mostly about the head unit, but it does cover the camera install too.
https://themustangsource.com/forums/...w-pics-455116/
Old Feb 3, 2015 | 11:08 AM
Andy H's Avatar
I just got a cheap one from ebay like this
http://www.ebay.com/itm/Waterproof-CMOS-Wide-Angle-Car-Rear-View-Reverse-Backup-View-Parking-Camera-New-/121218948132?pt=LH_DefaultDomain_0&hash=item1c39365c24
Then I took the lock out and the camera fits right in the opening perfectly. It was a super easy job. I also ran a switched hot wire to it so I could turn it on while driving instead of it just being powered by the reverse light. If you do this you'll need to install a cheap inline Diode to keep it from sending 12 volts to your backup light and turning that on while driving..... unless of course you want to give the people behind you a heart attack.
Old Feb 3, 2015 | 12:23 PM
Fear's Avatar
Waterproof CMOS Wide Angle Car Rear View Reverse Backup View Parking Camera New | eBay
breaking necks has the same result as a heart attack right
Thanks for all the help guys i appreciate it
Old Feb 3, 2015 | 12:26 PM
Fear's Avatar
how exactly did u take the lock out? just hollowed out the hole?
Old Feb 3, 2015 | 11:58 PM
GottaHaveIt's Avatar
trunk key hole 😆 fob then works fine . but took it out do not like what my eyes cannot see to trust.
Old Feb 4, 2015 | 12:11 AM
Fear's Avatar
sorry what? confused by what you mean
Old Feb 4, 2015 | 12:34 AM
i removed my trunk key & put the camera there. not many could tell. The trunk was still accessable by the key fob.
I don't like cameras so i took it out because i feel if i can see it with my own eyes or judge myself then i dont need to drive.
Old Feb 4, 2015 | 08:11 AM
Andy H's Avatar
I think it was only a couple bolts holding the lock in, don't remember for sure but I do remember it was really easy.
here is what it looks like with the camera, nobody would know it was there unless i told them.
Old Feb 4, 2015 | 06:15 PM
jim010's Avatar
I also put mine in the trunk key hole. Just some screws holding it in place. I made a bracket from a thin strip of metal to hold it firmly in place. I also installed a trunk release button in the car in case the fob fails.
Easy and clean looking to put it in the key hole.
Old Feb 5, 2015 | 12:23 AM
Fear's Avatar
ah got it! thanks man sorry bout that
Old Feb 5, 2015 | 05:29 AM
Scott2's Avatar
I have a Pioneer Navigation Receiver model AVIC-8000NEX and have been looking at the Pioneer ND-BC6 camera but it looks like the only place it could be mounted is on either side of the license plate light.
Does anyone have any experience with this camera? Where did you mount it?
http://www.pioneerelectronics.com/PU...Cameras/ND-BC6
Old Sep 4, 2015 | 09:22 AM
Briank's Avatar
$150 for the camera????? Wow! I got one from Aliexpress for about $10 and it is fine. I tried a transmitting type but found I got too much interference so went with a wired camera. It is a license plate mount similar to the one in the OP's post which is noticeable but I may paint the bracket to match the plate so it is not so noticeable - or perhaps the car color.
I like the key mount idea though, but I also like (but never use) the key lock just in case.
Old Sep 4, 2015 | 01:21 PM
Scott2's Avatar
I hear you, they are not cheap. Have it mounted now. Friend of mine said it could be converted to the key hole and I just need to see how he mounted his.
Old Sep 13, 2015 | 09:50 AM
Briank's Avatar
That is a great spot to mount it. I might have to relocate mine.
Old Dec 27, 2015 | 01:14 PM
randyre's Avatar
ooohh ooohhh Pics Please. Your picture link is dead.
Did you install it from the front or rear? the one I saw installed it from the inside with a homemade bracket like jim010
Old Dec 5, 2016 | 06:06 AM
SiBEERian's Avatar
Hi guys
I made it so
http://www.ebay.com/itm/Waterproof-C...cAAOSw0HVWCgX7
HizliBullet
Sep 2, 2015 06:58 PM
bigdaddy51200
Aug 20, 2015 09:25 PM
krnpimpsta
05-09 Interior and Audio Mods
50
May 21, 2008 06:46 AM
Skorch52
Jul 21, 2004 12:35 PM
