275/40/17 Question
Old Nov 18, 2009 | 10:21 PM
crewcutkid's Avatar
275/40/17 Question
All-
I'm currently running 17x9 wheels with the stock tires, and I have found a better tire for summer driving- the trouble is, I don't really know how it will look on my car. The tires I found are the Firestone Firehawk Wide Ovals that run 275/40/17. Since I'm running on a stock suspension, will these tires give my car that "4x4" look? The second part of the question is whether or not a 9" wheel will handle a 275 tire- anybody know?
Thanks for the help!
-Jim
Old Nov 18, 2009 | 10:35 PM
275/40/17's were the stock size tire on the 9" wheels on '03 and '04 Cobra Termis.
So they'll definitely fit a 9" wheel. Ford used them in a stock setup.
What size tire are you running right now?
1999Pony's Avatar
It will leave a little more space inside of the wheel well but it will fit. Lowering it will always fix it.
Old Nov 18, 2009 | 11:23 PM
crewcutkid's Avatar
Thanks for the replies-
To answer the first question, I'm currently running the stock PZeros...which I believe are 235/55-17. At the moment, they look almost stretched out because of the change in wheel width from 8" to 9."
As far as lowering it, I don't have a grand to play with right now for the FRPP kit (not just the springs).
-Jim
Old Nov 18, 2009 | 11:34 PM
Ministang's Avatar
The difference in diameter from the stock 235/55-17 to the 275/40-17 is an inch and a half, so you'll have 3/4" more gap between the top of your tire and the fenders. It would look terrible to some people who feel the stock fender gap makes it look like a 4x4, it wouldn't bother other people as much. As to whether the 275mm wide tire will fit a 9" wide wheel, yes, it will be fine, according to the spec chart for the Firestone tires on Tire Rack's website, wheel widths from 9-11" are ok for the 275/40-17.
Old Nov 19, 2009 | 09:06 AM
crewcutkid's Avatar
Ministang,
Thanks. That's exactly the info I needed! Awesome!
Thanks again, all!
-Jim
Old Nov 19, 2009 | 10:08 AM
gmantheman's Avatar
I wouldn't get 275/40/17. Too much wheel gap. I had 245/45/17 which is about the same diameter and I hated the look. True, you could lower your car would be too low. I would get 255/50/17.
Old Nov 19, 2009 | 10:16 AM
crewcutkid's Avatar
gmantheman- I actually found a set of Pirelli Rossos that are on sale- the size is255/60R-17. Plenty of sidewall, plenty of width. I really really like the firestones, but you are correct, they would make my car look like a roller skate. The 60 sidewall would be good- it will fill in the wheel well, and give me plenty of traction (I can let more air out at the track). When spring gets closer, I'll make my purchase!
-Jim
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
