20x10in Deep Dish Bullitt Wheels
Old Dec 11, 2005 | 08:51 PM
thestoogeo's Avatar
Here is my plan:
Front & Rear Wheels: 20x10in Deep Dish Bullitt Wheels
Front Tires: 275/30R20
Back Tires: 285/30R20
I have used the 1010tires.com calculator to compare the tire sizes and overall diameter to the Roush and Saleen wheels. It looks to me like these will fit and not rub in the front. The overall diameter is 672.84mm with the DDBW's (275/30R20) and 677.17mm with the Roush wheels (275/40R18).
I will be installing a big brake kit up front and need the 20x10in wheels to fit the big break kit otherwise I would be going with 20x8in up front.
Would there be any trouble with different overall diameters front to back? Should I stick with the same rubber all around?
If there is no rubbing will having 275mm rubber up front cause any other problems?
Does anyone have 275mm up front? Any rubbing?
Thanks for the help. I know I don't ask the easy questions.
Jon
Old Dec 11, 2005 | 08:58 PM
don_w's Avatar
I seem to recall many guys running 275 and even 285 up front. And a 275/30R20 is 1/2" shorter than the stock 235/55-17 tire. The 285/30-20 is also a little shorter than stock. Many of us run different size tires front and back with no issues (I have 255/50-17 up front and 275/50-17 in the back). You might also check the Exterior Mod forum... a lot of wheel/tire threads are there.
Old Dec 11, 2005 | 09:23 PM
thestoogeo's Avatar
Thanks for the info.
Jon
Old Dec 12, 2005 | 07:49 PM
05-1947's Avatar
run the 255/335 up front and the 275/35 out back and you will be happy.
the 255 fits the 8.5 very well and the 275 fits the 9.5 very well.
Old Dec 12, 2005 | 09:20 PM
dhof303's Avatar
275/45/17 all 4 corners on factory rims, no probs here, even lowered. But I bet with a 20" wheel you will have rubbing in the front and I would be willing to bet the rears won't clear the 285 no matter what the backspacing. JMO. Good Luck.
Derek
Old Dec 13, 2005 | 09:01 AM
thestoogeo's Avatar
Because of my big brake kit I will have to go 20x10 all around. From the looks of it 255/35 would fit the 20x10 but be a little on the narrow side. Has anyone run 255/35 on a 20x10 wheel?
Jon
Old Dec 13, 2005 | 10:07 AM
05-1947's Avatar
why would you need to go 10" wide in the front because of brakes.
Old Dec 13, 2005 | 02:40 PM
thestoogeo's Avatar
I'm not sure, I guess it was more of a hope that I could use the 20in DD Bullitts if I went with the 10in vs 8in. I talked to Mustang Tuning and they took the StopTech template over and said the 20x8in DD would not fit and they don't have the 10in to check. Does anyone know if there are 20in Bullitts that are not deep dish. I want 20's, but I also want some wheels that tie in with the mustang muscle car theme.
Jon
Old Dec 13, 2005 | 11:45 PM
GtStallion51's Avatar
I've had my 20's for just over 4 months now, and have had no problems. IMO 255 up front with 285 out back give a nice "mean" look. Does need to be lowered if your going with 20's though.
Old Dec 14, 2005 | 07:51 PM
thestoogeo's Avatar
That looks sweet. Post some more photos.
Thanks for all the feedback. I'm having so much trouble finding wheels that fit the StopTech 14in BBK.
Jon
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
Sep 10, 2015 12:44 PM
Gabe
Sep 7, 2015 03:30 PM
